Zumo 660
Zumo 660
Have 2009 screaming eagle road glide, just installed boom audio interface kit with new zumo 660. Followed lousy instructions but have no sound from GPS. Music stops when commands spoken but don't hear them.
Dealer gave me small cable (iPod navigational interface connector kit) with 2 wires that was supposed to be hooked into 6b plug terminals 4 & 5, other end to go to 35 pin plug into cavity 13 & 14.
Problem is 13 & 14 already have wires. Any suggestions?
Zumo
Any ideas on 35 pin cable and not hooking up 2 wire interface cable?
Do you have the HD Road Tech version of the GPS or the Garmin version?
I have read a lot of posts about using the NIM (Navigational Interface Module) and if that's what you're using, it only works with the HD version. I'm not read why but it seems like there's a difference in the way HD has their version wired inside the unit.
Also, I've read that there was an updated version of the NIM as some of the early units had problems.
I'm not sure if this is your problem or not but thought I'd mention it as something to consider.
Good luck in getting it to work I have the Road Tech 550 on my bike and I like it a lot, mostly for listening to satellite radio.
albngore
12-30-2011 11:57 PM
