BT2180.14 restore defaults??
I installed the BT2180.14 AMP AND SPEAKERS. Before flashing the radio at the dealer, I adjusted the screws in the module inside the batwing to an optimum listening level. Now after having the dealer flash the radio, I think I need to go back to the factory settings. Does anyone recall if they are in a set position that I can restore to? I figured I'd try here first before calling BT. Thanks.
You should post in the audio section and you will get better responses. I don't know why you would have had the dealer flash the bike. You don't say what bike you have. If you mean update the software that is different. If you are asking about setting the gains and hpf on the line leveler the installation instructions show the default setting. Again, I recommend you post in the audio forum.
