Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
nitrous tune
Old 10-25-2011, 10:11 PM
onaride63's Avatar
onaride63
onaride63 is offline
Default nitrous tune
any advice on tuning a 103 with a 30 hp shot of nos ?
motor is stroker crank ( cast ) welded,balanced, forged pistons and forged H beam rods.heads and cam as is in signiture.
would this set up handle a 40 shot ?
Old 10-26-2011, 06:47 AM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
DRAGO'S BIKE WORKS is offline
Former Sponsor
What is the the hp now. The stock cast crank will handle about 160/170 hp before it will brake left side shaft.
We've broke them all from R&R to S&S Darkhorse & RevPerf. Jims SE & and our own Dragos crank making way to much power lol.
Old 10-26-2011, 07:44 AM
BadBagger08's Avatar
BadBagger08
BadBagger08 is offline
How are you planing to ad the extra fuel for the NO2 shot? Dry or wet system?
The power commander 5 works best for a tuner and NO2 use. The ability to switch maps on the fly makes it ideal for nitrous.
You can spray about a 25hp dry shot without changing anything by having the spray bar directed at the cold air temp sensor and let the bike ad the extra fuel on its own. I have the Nozzle pointed like this anyways just in case the PC5 doesn't switch maps I don't run completely lean.
As far as tuning with a larger NO2 shot (35hp) you would need a base map that runs good off the bottle and then another map that would have the extra fuel added for the shot of NO2 at the intended rpm range of use. I would refrain from activating the NOS until 3,000 to 3,500 rps to help prevent crank abuse.
Old 10-26-2011, 09:36 AM
onaride63's Avatar
onaride63
Thats why I thought I would ask. I spun my crank. don't think it was the NOS. bike had 60g's when I put on the bottle. LOL...its a dry system. The nozzle is in my air filter tube spaying at the cold air temp . I'm going to use the power vision tune. It holds up to 6 tunes. only draw back is I have to turn off my bike to re-flash the ecm, but thats ok. Unlike the PCV its a flash tuner not a piggy back. I never hit my squeeze until 2nd gear @ 3000 rpm. Plan on having a performance tune, NOS tune, and highway tune for gas milage. What about timing ?
Old 10-26-2011, 01:09 PM
BadBagger08
I'm still trying to figure out what the stock Harley timing table is. (I have a stage 1 flash to complicate things even more) I haven't messed with timing, but you will want to retard it on the bottle and that should be some where around 35-32 deg btdc with a smaller shot.
Your crank looks like it should hold up now. Myself when min goes out I will be going 124" with a big bore kit from revtech while the cases are apart.
If your looking for some NO2 gadgets look here at DynoTune nitrous lean shut off switches, RPM activation switches, and they work with the FBW of the Harley's. I will be adding the dual RPM switch, use stage 1 to activate the nitrous above 3500 and the other to activate a LED shift light.
Old 10-26-2011, 10:11 PM
onaride63's Avatar
onaride63
Dyno tune is where i bought my set up. They do have some nice stuff. I called a guy about 3 months back ( like a numb nut I forget where). and He said a good rule of thumb as long as you not running 70 shot or above was retard 4 deg per 25 hp shot at wot with my system ( dry, horn button trigger ). I would like to have the switch that automaticley kicks in at a pre set rpm at wot....
07nighttrainaus
10-02-2017 12:00 PM
amkaos
04-10-2015 07:14 AM
mholl
07-14-2014 05:02 AM
Rooster37
11-25-2011 02:58 PM
GasCan
05-14-2008 10:43 PM
Quick Reply: nitrous tune
