Power vision nitrous maps
Old Oct 1, 2017 | 08:42 PM
07nighttrainaus's Avatar
07nighttrainaus
Default Power vision nitrous maps
I'm looking into a dyno tune dry shot for my bike. I'm currently running a power vision witj target tune. Had anyone found a way to add fuel and pull timing on the fly with the power vision? Or just use the air temp sensor and add the fuel to the cooler ait map? Ill be looking to run around a 15-30 shot. Also I'm guessing the injectors will need to be replaced with larger ones as I'm at around 105hp with stock 2007 injectors at the moment
Old Oct 2, 2017 | 12:00 PM
hrdtail78's Avatar
hrdtail78
I have done the PC5 on top of several flash base tuning systems. I use the dynojet multi function hub to turn the PC on and off. Works good. Never used the TT system with it. I can see how this might be counter productive. It might be making changes before PE mode starts to play effect, while you are trying to do it in the PC. For that I wouldn't allow 100 kpa or WOT be in closed loop for the NOS calibration.
Good luck.
flhchaz
EVO
14
May 7, 2015 03:27 PM
timberland
Nov 4, 2012 05:03 PM
gant
Aug 16, 2012 11:35 AM
Glide11
Jun 23, 2011 06:43 PM
travelingman
Jan 11, 2007 11:43 PM
