I had to install an aftermarket unit to complete the upgrade to a cv carb. My question is should locktite be used on the screws holding in place? If so what grade. I was worried about damaging threads in carb if removal is necessary.
Blue Locktite is good. I don't use Locktite on the air cleaner screws, I use lock washers...never had any issues with those three or the parts that screw into the carb body. I have had the air cleaner cover screw get loose so I use a little blue Locktite on it.
