New carb problem....
Well, it's not actually a carb problem, but an air cleaner problem. When I was working on the carb the other day, I noticed how bad of shape the gasket for the air cleaner was. We had some black U-channel at work, so I picked some up. Tonight, I was going to install it......WRONG! I guess I over-tightned the air cleaner cover screw, so now, all it does is spin. I must have broken the nut loose in the air cleaner bracket. I tried to put some tension on the screw and turn it, but it won't back out. I tried wedging a couple of screw drivers under the air cleaner cover, but the screw just spins. Has anybody run into this? Any suggestions????
Monty
Monty
DLSSOJC
09-04-2014 04:54 PM
nosillyname
Exhaust System Topics
06-17-2009 03:22 AM
