Front Brake sounds like a rattle snake or cicada
Old 09-29-2014, 05:52 PM
hitman1267's Avatar
hitman1267
hitman1267 is offline
Default Front Brake sounds like a rattle snake or cicada
I know weird right? I don't know what it is, the brakes work fine. When I press on the front brake it sounds like a cicada chirping. I may just change the pads, what else could it be?
Old 09-29-2014, 06:06 PM
motorend's Avatar
motorend
motorend is offline
My 14' fxdl does the same thing.
Old 09-29-2014, 06:34 PM
izzyryder's Avatar
izzyryder
izzyryder is offline
Check out my thread
https://www.hdforums.com/forum/dyna-glide-models/1002344-disc-brake-chatter-fix.html
Old 09-29-2014, 08:40 PM
JohnnyRebKY's Avatar
JohnnyRebKY
JohnnyRebKY is offline
Swish swish swish. Yep my 2002 wide glide does it too.well mine does it when it's freewheeling and not when brake is depressed. Brakes look good, rotor is fair. I decided to just ignore it until winter when I have more time to tinker and less time to ride.
You on the other hand may need some pads. Sounds like metal on metal chirping. Did u take a peak and see how much if any pad is left?
Old 09-30-2014, 09:19 AM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is online now
I've heard lots of stories about newer, better, quiet pads. Anyone have any opinions on this? For less than 2 bucks I would give Izzy's tip a try. I've been thinking of doing it myself.
Old 09-30-2014, 06:07 PM
Iron obsessed's Avatar
Iron obsessed
Iron obsessed is offline
Yes my 14' fxdl, same, dealer said nature of the pad, only happens when I brake, would assume after market pads would fix issues...
Old 09-30-2014, 07:26 PM
2500hdon37s's Avatar
2500hdon37s
2500hdon37s is offline
Received 1,549 Likes on 667 Posts
Mine only make the smallest swish swish and squeek on occasion when lightly braking. I figure it just the pads. I also ride stretches of gravel nearly every day.
I'm gonna say its the pads. you might also try to see if blowing brake dust and etc. out of the caliper and pad area helps.
Old 09-30-2014, 07:36 PM
BigDogIdaho
Maybe some brake clean to try to clean off dust?
Old 10-01-2014, 08:04 PM
PegasusHD's Avatar
PegasusHD
PegasusHD is offline
2nd Gear
My opinion is it's the rotors. They are cross drilled and when the pads pressurize and goes over the hole, it makes the noise. I bet solid rotors wouldn't do it.
Old 10-03-2014, 07:14 PM
hitman1267's Avatar
hitman1267
Hahaha while riding I would be like "there a lot of cicadas out chirping today". Pads look good, brakes just fine. I'll see what new pads do.
Quick Reply: Front Brake sounds like a rattle snake or cicada
