dyna seat
Old 01-26-2015, 10:56 PM
Lentini93's Avatar
Lentini93
Lentini93 is offline
Default dyna seat
Hey guys, just purchased a reduced reach seat for my streetbob. before it had the stock seat. I used a nut and bolt I have laying around in the garage for the back fender, but the front of the seat by the tank moves quite a bit... what gives? Am I missing a part? I figured it was bolt and go? Doesn't move if im sitting on it, just off I can scoot it around.
Old 01-26-2015, 11:05 PM
09dynafxd's Avatar
09dynafxd
09dynafxd is offline
My 2 up seat did the same thing until I did my tank lift and had to bend my metal tab that goes under the rear tank mount. If I were you I would take it back a little and bend that tab a little at a time until it has a better fit in that slot.
Old 01-26-2015, 11:06 PM
Lentini93's Avatar
Lentini93
Thanks. Bend up or down?
just want to do it right the first time...
Old 01-26-2015, 11:31 PM
loopie's Avatar
loopie
loopie is offline
have a look at the seat bib 52036-08, I used this with the reduced reach solo seat, may be space it out a bit with some foam
Old 01-26-2015, 11:43 PM
09dynafxd's Avatar
09dynafxd
I bent down from my lift. I would try up first and see where you get. I have also seen a few guys take electrical tape and wrap that tab for a tighter fit and it will prevent it from rubbing through the paint with the metal to metal contact.
Old 01-27-2015, 03:52 AM
Lentini93's Avatar
Lentini93
Electrical tape worked perfectly.
Old 01-27-2015, 07:46 AM
09dynafxd's Avatar
09dynafxd
Good. Hope you like that new seat.
RoBeau
2014-2023 Touring Models
04-29-2019 02:00 PM
TXWarthog
EVO
11-14-2017 08:12 AM
1150ap
12-27-2014 09:54 AM
SgtSkiddz
09-22-2011 08:20 AM
tbone52
09-22-2006 12:53 PM
Quick Reply: dyna seat
