Changing front pulley??
I went from 32T to 30T and there may be other differences because of the model year but here is my Thread:
https://www.hdforums.com/forum/dyna-...y-install.html
I believe two teeth in either direction will require a belt change. Get the steel sprocket, my aluminum was gone in 15 k and had a big lip that made the belt squeal, that's what made me investigate, then change from a33 to the 34. I got away not changing the belt with the 33 but had to change belt with the 34
