Starter loud clicking noise.
Old 03-09-2016, 06:28 PM
drhooligan's Avatar
drhooligan
drhooligan is offline
Default Starter loud clicking noise.
2007 Wide Glide with new battery last year on tender all winter. Bike started fine last week. Now it makes a clack, clack, clack noise and doesn't spin or apparently engage the starter motor. Battery reads 12.8 volts. Could this be the starter relay in fuse box, solenoid? Thanks in advance for advice.
Old 03-09-2016, 06:49 PM
joe40x's Avatar
joe40x
joe40x is offline
Check your grounds
SIDECAR BOB (03-13-2016)
Old 03-09-2016, 07:31 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
Clean and tighten the battery terminals, ground (as above) and starter cable connections,, just be sure the simple stuff is right before you go digging deeper.
Loose connections can work fine for awhile, then arc or oxidize and fail.
Old 03-09-2016, 07:43 PM
itscaptaincody's Avatar
itscaptaincody
itscaptaincody is offline
Get the battery load tested at autozone/checker, etc. I had the exact same issue and it was the battery (mine was a year old as well)
Old 03-09-2016, 07:48 PM
04FXDI's Avatar
04FXDI
04FXDI is offline
This must be the season for bad batts, I went and loaded mine today, (year old) and got nothing, even after spending the entire winter on the tender it barley had enough juice to turn lights on. I dropped it on my big charger and it came up a little bit, just enough to screw up my key fob settings. Thanks another bridge I have to cross.
Old 03-10-2016, 01:07 AM
rogersachs's Avatar
rogersachs
rogersachs is offline
Smile
I had the same noise and it was the solenoid. Changed it and all is well.
roger
Old 03-10-2016, 03:17 AM
AKFXD's Avatar
AKFXD
AKFXD is offline
Is it making multiple clacks with one start button push?
Is it a loud noise or a quiet click sound?
Old 03-10-2016, 11:06 AM
drhooligan's Avatar
drhooligan
Multiple loud cliks with one push of the start button.
Old 03-13-2016, 10:19 AM
drhooligan's Avatar
drhooligan
Took the battery to Autozone and had it tested. It was bad and only about 16 months old. I cleaned all the grounds and solenoid contacts while at it. Thanks for the advice guys!
Bubba Zanetti
07-13-2019 02:58 PM
StephenBooth01
Shovelhead
27
01-30-2015 09:34 AM
razman427
11-02-2012 06:03 PM
rstekeur
11-09-2011 08:54 PM
cadore
03-11-2010 07:32 PM
Quick Reply: Starter loud clicking noise.
