kick stand with taller shocks?
Old 04-13-2016, 11:03 AM
666streetbob's Avatar
666streetbob
666streetbob is offline
Default kick stand with taller shocks?
hey guys i currently have the burley slammer shocks and went with the 1" under kick stand. i want to go to a 12" shock which as we all know is 1" over stock. would i need to go with a 1" over kick stand or will the stock kick stand work?
Old 04-13-2016, 11:43 AM
union53's Avatar
union53
union53 is offline
I did not need a 1 inch longer stand. The bike does have some lean to it and I try to put the stand up slope if I can. Originally I did look for a long stand but didn't have any luck. Did find a ton of shorter stands.
If the lean is too much for you I've seen some weld a piece on the bottom of the stand foot to prop it up a bit more. On one of my older bikes I would carry around a small piece of plywood. Small enough to fit in my jacket pocket. Got the 1/2 inch extension and gave the stand a bigger foot print so it was less likely to sink.
Old 04-13-2016, 11:45 AM
izzyryder's Avatar
izzyryder
izzyryder is offline
Take the kickstand off the bike and have the resting tab welded to make it larger. This will decrease the lean of the bike.
Old 04-13-2016, 11:50 AM
fxdlx's Avatar
fxdlx
fxdlx is offline
I didn't know that. I thought 12" was stock length...
Do you still have your stock kickstand?
Old 04-13-2016, 11:57 AM
666streetbob
i got it somewhere in the garage...i could have sworn 11" was stock, i could be wrong though...
Old 04-13-2016, 12:11 PM
izzyryder's Avatar
izzyryder
Old 04-13-2016, 01:10 PM
izhd's Avatar
izhd
izhd is offline
Old 04-13-2016, 01:48 PM
Bagged64's Avatar
Bagged64
Bagged64 is offline
Originally Posted by izhd
I just ordered the same thing due to I went with 13" shocks and in some instances the lean is too much.
Old 04-13-2016, 03:29 PM
izhd's Avatar
izhd
izhd is offline
Yeah I have 13.5, on flat it's fine, but on the hill can be a bitch
Old 04-13-2016, 04:06 PM
fxrnutt's Avatar
fxrnutt
fxrnutt is offline
+1 more on the bungking block....
Quick Reply: kick stand with taller shocks?
