Cams and dyno tune question?
So I dropped some fueling cams and screaming eagle adjustable pushrods in my bike but haven't started it up yet becaaauuusseeee, I was gonna get it dyno tuned by Rc cycles in NorCal, but my problem is another shop told me to ride it without a tune for a while? It's a well known shop too, but I have read that it will run like complete **** without a tune? If anyone could fill me in a little more on this it would be greatly appreciated!
It may not necessarily "run like ****" without a tune, but it definitely won't run at it's best, either. In my opinion, if the engine is broken in there is no reason whatsoever to run it on the street before putting it on the dyno. On the other hand, the dyno isn't exactly the best place to discover that one (or more) of your pushrods aren't properly adjusted (or some other cam install issue) so it probably would be a good idea to run your engine long enough beforehand to sort any such issues out.
Not sure the logic behind that advice but I can tell you I ran my bike with cams with a tuner and I recently went to RC and had Bob dyno tune my bike and now it runs completely better. Before I was having problems and now it runs perfect.
Did you ask the shop who told you that why they wouldn't recommend a dyno tune? I have a coworker with a stage 1 who's never had a tune. He just hit 50,000 miles and he said he's never had any problems. I believe once you put cams it's a must.
If you try it and you have problems then you proceed to the next step.
If you try it and it runs great and your gas mileage increases and your bike has lots of power, idles smooth, good take off and top end then if your happy then that makes good logic.
Not all tuners will keep up with your mods.
For the money you will pay once you could get a good auto tuner and ride!
I don't like to have to be without my bike, that's why I do everything I can do myself.
Yes it possible that it could be a little better but you ask my friends if I'm lacking in the power.
I think not.
I think not.
