Valve To Piston Clearance...
First thing I did was take a set S&S lifters and take all the oil out of them so I could completely collapse them into a solid to be able to take an accurate valve to piston clearance..
I used the old .030" head gaskets and reassembled everything with playdough in the valve reliefs.. I set the pushrods to zero lash and turned the motor over several times just to make sure there was no interference.. The motor rolled over without issue..
I disassemble everything and removed the cylinders heads to measure the playdough/clay and on the front cylinder the actual clearance on the intake valve relief was about .030" and the rear was at .040".. The radius seemed pretty good but I'm not the most comfortable with the clearance..
I'm going to open the valve reliefs a little.. I think if I add .030" to both front and rear I should be good..
These measurements are from a solid lifter so even if the lifter pumps up completely I think I should still have the clearance I need..
I have at least .060" on the exhaust both front and rear so I should be good there.. The exhaust valves just barely contacted the playdough..
Looking for a little confirmation, thanks...
The Red playdough is the rear cylinder and the multi color is the front.. Wish I had some plain old grey clay...
I would think that 0.060" as a minimum clearance on the valve flat, I prefer to see more. The radius is ok at 0.030".
These are set at 0.020", and with the 0.030" head gasket will give plenty of room.
