Cutting Cat out update
Old 08-10-2016, 07:35 PM
Archex's Avatar
Archex
Archex is offline
Default Cutting Cat out update
Thanks to all over the past few weeks. Cut my cat out last night and love the new sound. Cat out, slip ons installed. New breather and I think I am all set for this year.
Thanks again everyone.
Old 08-10-2016, 09:18 PM
robbyville's Avatar
robbyville
robbyville is offline
Great to hear, enjoy! Sound byte?
Old 08-10-2016, 09:19 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,953 Likes on 1,685 Posts
Originally Posted by Archex
...Cat out, slip ons installed. New breather and I think I am all set for this year...
Did you tune it?
Old 08-11-2016, 12:13 AM
k-weaver's Avatar
k-weaver
k-weaver is offline
Originally Posted by IdahoHacker
Did you tune it?
X2...Making it breathe better is always a good thing but you gotta compensate by tuning. Without you will likely run lean which means hotter temps and pops.
Old 08-11-2016, 05:01 AM
Archex's Avatar
Archex
Archex is offline
Did not tune it yet. I wanted to run it for day or so too see how it reacted. I am getting a ton of decel popping. Tuning seems to be in order.
Old 08-16-2016, 03:45 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
The deceleration popping is from a lean condition in the idle circuit caused by less restrictive exhaust. Most will do that if you change just the exhaust. With a tuner, adding 5-8% more fuel in the 0-1500rpm column will all but eliminate it.
Old 08-16-2016, 03:51 PM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
You edited your post; I edited my response
Decel popping and burbling is a creation of fuel entering the exhaust under off throttle conditions; when the AFR is right it burns off in the hot exhaust; adding fuel in off throttle situations will alter the AFR and prevent the popping and burbling, as Tucci has now posted...
imboden
05-29-2018 08:16 AM
PHX M8
Milwaukee Eight (M8)
43
07-12-2017 02:13 PM
digdug
05-15-2014 01:53 PM
Wpittman
09-15-2012 07:51 PM
rowdy82
07-28-2012 07:31 PM
Quick Reply: Cutting Cat out update
