cylinder temps
cylinder temps
What is the normal, or at least the average cylinder temp.
Finally took a reading on my bike and my daily ride into work. stop and go city traffic about 15 miles. Front cylinder was around 275, rear was at 245.
Temp was around 70 with about 80% humidity.
I am saving for a tuner so I can watch the temps etc.
Bike has Python Pipes, and I put the A.N Big suck on just to see how I like it "Can remove to see if the temps go down" and yes I know I need a tuner read above.
With Powervision you can watch the Engine Temp in real time. This value is not the Oil Temp. It is the Cylinder Head Temp taken from the sensor installed, I believe, on the front cylinder head.
On my bike in summer traffic, I can see high enough temps (over 300) that make me cringe and I switch the screen to another set of gauges. But once I get back on the freeway, I can watch the temps drop 50+ degrees.
I would have thought the rear head was hotter than the front simply because of less airflow on the rear.
Agree I would have thought the rear would be hotter. I will test again when I get home to see what the temps are. I didn't think it was too bad but wanted to see what others are seeing. I am measuring on the outside with a hand held device.
jmeiers, you're on the mark. The PV's 'engine temperature' is actually based on the sensor readings from the engine sensor located on the rear of the front cylinder up near the head. The Power Vision uses an algorithm to determine the displayed engine cylinder head temperature since there's only the one sensor.
Edit: The PV reads the cylinder head temperature and displays it as ET, engine temperature. As Fishonsc posts below, the cylinder head temperature is an algorithm based on ET and the intake temperatures.
When I have my Power Vision mounted to the bike I monitor cylinder head temperature, engine temperature, battery voltage, and intake temperature.
On some warm 90+ degree days earlier this month I was seeing 317° head temperature, 220° engine temperature, and 112° intake temperature as I was riding...
Last edited by TinCupChalice; 08-30-2016 at 12:17 PM. Reason: Mulit-tasking; don't do it folks!
natedog_37 (08-30-2016)
jmeiers, the PV's 'engine temperature' is actually based on the sensor readings from the engine sensor located on the rear of the front cylinder up near the head. The Power Vision uses an algorithm to determine the displayed engine temperature since there's only the one sensor. The PV displays the actual engine sensor temperature if you set your gauges up to monitor cylinder head temperature.
The value I thought was Engine Temp has a Label of ET. So you are saying there are 2 values available? My bike is at home in the garage. I will look this evening. Thanks.
Just can't wait to get the PV and starting making more power.
Then on to a better seat OMG the stock seat kills me AS* after 250 miles.
Received 3,940 Likes
What is "normal" and what is good or bad for your engine are two different things on the Twin Cams.
Click HERE for a report on how temps are read, whey they are what they are, when damage starts occurring, and what can be done to keep the Twin Cam operating in the optimum temperature range....both for performance and longevity.
Great info also thank you.
By the way. My ET runs about 230. Around 275 in town. 07 96" TC.
