Touring wheel dual disc on fat bob forks?
Old 03-08-2017, 12:17 AM
JoeBobber's Avatar
JoeBobber
JoeBobber is offline
Default Touring wheel dual disc on fat bob forks?
currently I have fat bob trees on my 08 street bob and am running a 21" wide glide wheel. I want to convert to dual disc and a fatter front tire. My thought is to switch over to fat bob fork legs and get a touring wheel , rotors, calipers and 11/16 master cylinder. Anyone know if all this should bolt right on or will the touring wheel be an issue. I know I could just go with a fat bob wheel and brakes but there are more touring wheels options on the used market. Also what to do about the fender, currently I use spacers with my original mid glide SB fender.
Also if you have done dual disc did you change your fork fluid to heavier weight or fork springs to deal with the added dive.
Thanks for any further insight.
Old 03-08-2017, 05:24 AM
blueangel73's Avatar
blueangel73
blueangel73 is offline
I am in this same boat right now. Looking for a front touring hub to lace to the rim and spokes I already have.
Old 03-08-2017, 06:35 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,236 Likes on 1,812 Posts
Use Low Rider Sliders if you want NO Issues with the Touring front wheel...otherwise Machining is in your future
Old 03-08-2017, 06:38 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
The Fat Bob slider moves the right caliper mount inboard a little, correct?
Old 03-08-2017, 06:55 AM
multihdrdr's Avatar
multihdrdr
Left and Right...
Left a lot, Right a little (relatively)
Old 03-08-2017, 07:03 AM
cggorman's Avatar
cggorman
cggorman is offline
Gotcha. You happen to know why? Seem senseless to me.
Old 03-08-2017, 08:20 AM
sharkey's Avatar
sharkey
sharkey is offline
Following this thread...
I have an 08 Fat Bob and want to change out the wheel to a cast spoke touring style; I have one in hand from an 08 FLH...so I am going to have rotor alignment issues? Hmmm...
Old 03-08-2017, 09:03 AM
multihdrdr's Avatar
multihdrdr
I don't really know, I mean I have some ideas, but that's all.
But I don't think it "senseless" to the HD engineers...they typically have a reason for things
multihdrdr's Avatar
multihdrdr
alignment issues?...Yep
Read this and replace SBob with FBob...
https://www.hdforums.com/forum/dyna-...s-on-fxdb.html
I'm more ok with milling the sliders now, but I still like milling/facing the Touring wheel if someone has the resources.
Old 03-08-2017, 09:39 AM
cggorman's Avatar
cggorman
cggorman is offline
Facing off the hub is easier. I'm planning to do that myself on my lathe. I don't have a mill at home. I could take the slider to work and do it there, but it's a helluva lot more work.
JoeBobber (03-09-2017)
Quick Reply: Touring wheel dual disc on fat bob forks?
