wideglide for fxr
Old 12-22-2005, 01:22 PM
vjt_1999's Avatar
vjt_1999
vjt_1999 is offline
Default wideglide for fxr
can i put a softail frontend on a fxr.....i really like the look of the wideglide as opposed to the narrow glide that comes stock on a fxr....
will it fit without any mods to the bike .............. would really like to put a streetbob front end on it ... they look great .................
Old 12-29-2005, 01:22 PM
vjt_1999's Avatar
vjt_1999
vjt_1999 is offline
Default RE: wideglide for fxr
has anyone put a wideglide on an fxr....... any differance in handling???
how hard was it to do??
Old 12-29-2005, 07:54 PM
Beeracuda's Avatar
Beeracuda
Beeracuda is offline
I've got a friend that has that done on his FXRS-CON. Sorry, I don't know the details....
Old 12-31-2005, 07:20 PM
79fatbob's Avatar
79fatbob
79fatbob is offline
I have a wide glide front end on mine, but it was done before i got the bike and am still doing it up, so have not riden it yet.
As long as the triple trees has the same size mounting stem there should not be any difference, will post a pic soon
Old 12-31-2005, 07:42 PM
79fatbob's Avatar
79fatbob
79fatbob is offline
Old 01-21-2006, 09:09 AM
PROFX's Avatar
PROFX
PROFX is offline
5th Gear
Wide Glide front end is an easy swap for the FXR. Only thing to watch if your using stock Softail trees is the stops on the lower tree. They will have to be cut back to allow for a full side to side turn. Most after market trees that use 2 screws bolted into the top of the lower tree for bump stops work perfect with the stock frame stop that's welded on the lower section of the neck. I've done many of these easy conversions including a wild 16" over front end with 55 degrees of rake (FXR Chopper) and they all work great with no ill effects. [8D]
[IMG]local://upfiles/7495/03838283BCBB4C099CAF730457B0E9C4.jpg[/IMG]
Old 01-21-2006, 02:18 PM
Y2K's Avatar
Y2K
Y2K is online now
Received 3,177 Likes on 1,333 Posts
There are kits out there to use your existing forks with wider trees so you wont need a whole new front end.
You'll prolly want to switch to a 21" front wheel with it though.
Old 01-29-2006, 06:44 PM
1984fxrs's Avatar
1984fxrs
1984fxrs is offline
stock fork tubes are 35mm on my bike ... would really like to get 41mm tubes...... what i would really like to do is get a streetbob front end and put that on... they look great .............
Old 02-20-2006, 02:12 PM
grizzly's Avatar
grizzly
grizzly is offline
ORIGINAL: 1984fxrs
Street bob front ends measure the same as the other dynas......Now the Wideglide has wider diameter...43mm I beleive. Regardless, they are wider than the other bikes in the Dyna lineup. Street bobs, Supers, ect all the samefront end.
If you just go with the trees and use your own tubes, you will still have to get some hardware for spacing the wheel and fernder. I suppose you could just "spread" the mounts for the fender, but the wheels definatly will need some spacers.
Personally, for looks, I think wide Glide and springer front ends are awesome. Performance in the twisties...no, but looks...HELL YEAH!
Old 02-20-2006, 02:13 PM
grizzly's Avatar
grizzly
grizzly is offline
ORIGINAL: 79fatbob
Never seen the horn there, at least with the cowbell on it....cool!
Quick Reply: wideglide for fxr
