Kickstand spring maybe?
RE: Kickstand spring maybe?
Haven't seen posts in a while, but if you look for the dyna clunk....some folks found it was the kickstand. I know the rubber stop on the frame on mine was not in the right place and it made the kickstand hit the frame.
And while you are on the ground checking it...I have read a few posts about the kickstand spring coming off...I used safety wire on mine just for fun
My kick stand fell shortly after I got it. We were going down the interstate. I sounded like the bottom of the engine coming apart. The spring was hanging and the stand was flopping. We tied it to the frame and went to the dealer. The rubber bumper was misaligned. They repositioned the bumper and reattached the spring. Haven't had a problem with it for 2 years and 28,000 miles. Also had a big clunk when I hid a bump right after the dealer replaced the 8 deg. injectors with 25 deg. injectors. Seems the rear gas tank mounting bolt is slightly longer than the front and they got them mixed up reinstalling the tank. The bolt bottomed out in the acorn nut and was not getting the tank tight. A simple swap of the bolts took care of that.
Never had the noise, but my kick stand would pop up as soon as I stood the bike up. The problem was that when puting it down, I would have to hold it out while I set the bike on it... I never gave it a thought, but when I traded it in they asked me about it. I always thought it was a safety thing so you would not drive off with it down(I have never done that) but I could see where it may happen... But they tell me that is not normal? I guess I will see when I get the new bike... I traded it in as I will have no part in a bike with a malfunctioning kick stand...LOL J/K!
crazytrain69
05-08-2009 09:27 PM
