Sissy bar removal help please.
Well, I'm going solo with the motor bike.
I've attempted it once a month or two ago, to remove the sissy bar that is.
I have a 2007 FXDL Low Rider.
The problem here is the bolt that holds the rear turn signals in place comes from the back side of the fender, through the strut, and it is a looong bolt.
I tried removing it, but it bumps the tire and will not clear it.
Anyone have similar problems and conquere it? Or do I need a lift in order to drop the rear tire to clear?
Thanks folks.
Thanks folks.
RE: Sissy bar removal help please.
On a superglige, custom, or wideglide, jacking up the bike should work fine, but on the low rider and street bob it makes no difference. I had the same problem when I put the rigid mount side plates on my bob a few months back, then again when I took them off mine, added the detachables and put the rigids on the ol lady's 07 bob. The best way I found to do it is so simple its almost embarassing.
The two bolts on each side of the fender go through the same bracket that has two 1/2" sleeves on either end for the bolts to go through. If you take both bolts out, and take a screwdriver to the inside and pull the bracket out, it allows you to turn the whole mess upward enough to push or pull the bolts out above the tire. It is still tight, and may rub a bit, but it is easy enough to do. I did mine that wat even with the SE 180 tire on there. I wish I still had my old fender struts and hardware and could post a pic of what the bracket looks like. Dont be discouraged man...
Maby another forum brother can post a pic of the inside fender bracket, it looks like a flat stamped oval with two sleeves in the ends.
[IMG]local://upfiles/21800/13FCE1C4B18E4C1F8E1595BC7488B1E2.jpg[/IMG]
update
as an update, I was able to get it off, it was a sure pain though... this without a lift, however.
it has two bolts holding the turn signals on, and two in the middle of the fender. thats it, the only other strut bolt is holding the shock on and i wasnt about to mess with it.
it just took time and lots of patience, which is not common with me.
thanks to all
thanks to all
tcatnat
09-06-2010 04:38 AM
