aftermmarket headlight bulb for an 07 street bob
Old 03-29-2008, 08:40 PM
freebyrd's Avatar
freebyrd
freebyrd is offline
Default aftermmarket headlight bulb for an 07 street bob
need something brighter thr stock bulb sucks ***
almost got me killied out in the country it was so dim
freebyrd
Old 03-29-2008, 08:47 PM
hk_shooter's Avatar
hk_shooter
hk_shooter is offline
Default RE: aftermmarket headlight bulb for an 07 street bob
I got a PIAA, that gives off a blueish/white color.
It's pretty bright.
Old 03-29-2008, 09:46 PM
CCPD's Avatar
CCPD
CCPD is offline
I use the Sylvanya SilverStar which is similar to the PIAA in color and intensity. I have not used a PIAA so I can't compare the two to tell you which is brighter, butthere are many posts about the two bulbs and many say the PIAA is a little bit brighter.The SilverStar is a bit easier on the pocket book. The problem with these bulbs though is that they create more heat and some forum members have reported damage to their headlight assemblies. I have had my SilverStar in for several months now without incident.
Chris
Old 03-29-2008, 09:49 PM
freebyrd's Avatar
freebyrd
freebyrd is offline
looked there and didn't see anything, i googled it but all i got was folks selling the whole headligght assembly
all i want is a brigter better bulb
freebyrd
Old 03-29-2008, 09:50 PM
hk_shooter's Avatar
hk_shooter
Good point, CCPD.
So far, so good with mine.
Probably 3K + ( miles)on mine and no excess heat issues, so far....
The Sylvania is less expensive, for sure.
Old 03-29-2008, 11:03 PM
RAWHIDE07's Avatar
RAWHIDE07
RAWHIDE07 is offline
Received 37,234 Likes on 12,891 Posts
The PIAA superwhite is more expensive($40 Dennis Kirk)but it is a heavy duty anti-vibration bulb that may last longer.You can try this first and if you want more add driving lights.
Old 03-29-2008, 11:26 PM
jeffbcn's Avatar
jeffbcn
jeffbcn is offline
I've put in two Sylvania SilverStar Ultra lamps in this year. They are much brighter than stock but the high beam burns out quick if you keep it on.
Old 03-29-2008, 11:43 PM
RAWHIDE07's Avatar
RAWHIDE07
SO,I have only had the PIAA for a few months,do they last longer than the sylvania's?Any feedback appreciated.(I'm not trying to steal this thread since the answers will benefit freebyrd also)
Old 03-30-2008, 12:14 AM
Gulfstream's Avatar
Gulfstream
Gulfstream is offline
Been there, done that...the Sylvania Silverstars burn out quick, I only got about 4 months out of each (2) that I tried. Best bang for the buck is the Osram 70/60W Rally Bulbs, bright but don't pull too many amps that will fry your wires. Osram also makes the original Silverstar which are good too. They're available from some specialty shops (try google) and there's a vendor on eBay selling them.
Old 03-30-2008, 03:59 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
I use a star bulb as well and the fogs i put on under my trees! crazy bright!
Quick Reply: aftermmarket headlight bulb for an 07 street bob
