Mirror with Auxiliary Running Light and Directional Indicator
RE: Mirror with Auxiliary Running Light and Directional Indicator
I have the Kuryakyn LED mirrors and really like them as they clean up the bars. They were reasonably easy to install, but you do have to cut and splice or solder. I didn't bother with the load equalizer because the rear flashers have incandescent bulbs.
[IMG]local://upfiles/16528/FE51091E69444CAAA5620B7AE2B05687.jpg[/IMG]
Location: Back in the Good Ole USA. South Carolina to be exact.
Hey AirBorne, I have the same Kuryakyn LED set up on my 94 FXDLas ktm. It was a little tedious to install but not bad. My setup required an equilizer. I am getting the HD units like you are showing in satin black for my FXDF. I'll probably let the dealer put em on. No time for tinkering anymore.
Oh Hell!!! Talked to a mechanic at the dealer, he said it would be about three or four hours to install. $196.00 if it's three, $260.00 if it's four. I will be installing these myself. I'll update when I get it done. Probably take me about an hour.
I have been looking at them also, I seen a black set at HD for $299, BUT I was at a Indy that said he can get the K's for $130 + 2 hours ($60 per)+ a 6 pack = $260 out the door,
He doesn't drink , beers for his OL.
he builds chopper and custom work, he's putting on all bikes he builds.
I installed my Kurys in about an hour. I'm no rocket surgeon either. Dealers pad everything with excessive hours. Mine wanted four hours at $85 per to install chrome sliders. I did it in less than two including new Progressive springs. He claimed they pad the labor to cover their liability costs when bikes fall off lifts or other technician-caused damage happens.
ORIGINAL: jluvs2ride
Because I've been looking at these also, in black...
From the website: "The wiring is concealed in the housing and stem, and is easily connected to the Original Equipment wiring harness." - sounds like 'plug-n-play' to me
CHD has them for $239.96
