Is there a noticable increase in power with the stage 1 "kit"?
For those of you who have installed the stage 1 download,slipons and ac,did you gain an increase in HP in the upper rpm range?I know the redline is 6250 after the download so is your bike faster in passing situations now?Since the dyna's are the lightest of the big twins I figure a modest power increase would be more apparent.
Can't speak for a TC96, but I'd guess that a stock FI TC88 dyna does about 65HP? HD does not publish this spec - and for good reason.
An air filter + pipe + fuel management mod (call this stage1 if you like) put my peak HP at 74. That's over 13% increase and is certainly quite noticeable (lower gas mileage is quite noticeable as well).
My butt dyno says a Stage 1 provides a VERY noticeable increase in pull from the mid to upper RPM range. I lost a little bit of that awesome low end torque ... but my scoot pulls forever in each gear and I can hit triple digits easily now, whereas it used to scream to 90 then sort of bog down. Also I can cruise all day at 85 - 95 mph on a road trip. He just purrs smoothly in that range while eating up the miles.
Do it. You'll like it. You'll next be thinking of cams and port/polish.
