Harley Fork Oil
Old 10-07-2008, 08:55 PM
Budds's Avatar
Budds
Budds is offline
Default Harley Fork Oil
Manual recommends Harley Type "E" Fork oil........
Any thoughts on an alternative Oil ?
Thanks in Advance.
Old 10-07-2008, 09:31 PM
Crushr's Avatar
Crushr
Crushr is offline
6th Gear
Don't have your answer but wanted to add a question to this subject. I was thinking about changing the sliders on the front forks, (from black to chrome). Is this difficult? Can it be done in the garage or should I let the local Harley shop tackle this for me?
Old 10-07-2008, 10:50 PM
hdslam's Avatar
hdslam
hdslam is offline
se heavy duty. You will get a smoother ride and front end will not dip so much when braking. Would not go back.
Old 10-07-2008, 11:06 PM
dynamac's Avatar
dynamac
dynamac is offline
I put in the Heavy duty fork oil, definately stopped it from dipping so much. Changing out the sliders is a garage job, only takes a few hours.
Old 10-08-2008, 03:28 PM
HDDyna2006's Avatar
HDDyna2006
HDDyna2006 is offline
This is a 20 K service, how important is doing it close to 20k?
Old 10-08-2008, 03:49 PM
rounder's Avatar
rounder
rounder is offline
fork oil:
1. don't panic
2. screamin eagle improve the front of my ride...
3. changing slider is a PITA.. I got some chrome ones that H-D makes that fit around the slider for 41mm forks. go that route(if you can for the 49mm front end) they look cool for chrome.
Old 10-08-2008, 03:51 PM
rounder's Avatar
rounder
rounder is offline
see they look cool!!
Old 10-08-2008, 03:58 PM
HDs4me's Avatar
HDs4me
HDs4me is offline
Try Belray Fork Oil.
Type "E" is 5 weight - the lightest one
Type "B" is 10 weight
Type "screamin' eagle" is 15 weight
Type "screamin' eagle racing oil" is 20 weight ( Not intended for street bikes)
Old 10-08-2008, 04:23 PM
Budds's Avatar
Budds
Budds is offline
This is what I was looking for..............
Thank You Sir !
Old 10-08-2008, 09:52 PM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
I bought/used a litre of 15w BelRay fork oil from my local metric shop. More than enough to refill my forks. I did it at 5,000 miles and the factory oil looked like shat.
Quick Reply: Harley Fork Oil
