bike hits neutral when going from first to second
i know this happens to everyone i think its happened occasionally on every bike i've owned but my 07 bob did it like six times yesterday
in case you don't know what i mean your at a stop and you shift down to first and take off, on that first upshift when you should be going from first to second you hit neutral instead,
so you have to engage the clutch again and shift once more to get moving, what cause's this am i just not giving it a good enough up kick?
cause when i think about it and give it a good solid shift everything's fine and it shifts smooth
i should mention that i ride with highway pegs and have mid controls and shift with my heels
bottom line is , this just inconsistent shifting from me, or potential tranny problem?
thanks for the link but i have no trouble finding neutral especially since doing the clutch adjustment,
when i did get home yesterday i reached down and the rubber boot that threads into the shifter lever had unthreaded itself about 7 or 8 full turns so that could have been taking some of the energy of the shift i tightened it back finger tight,
i'll get some channel locks and snug it up good and take it for a ride and see if that was the problem
Received 4,314 Likes
When making clutch adjustments are you doing the adjustments on a cold(room temp) drivetrain? Also too much oil in the primary could cause missed shifts or erratic clutch engagements. I've hit neutral once in awhile but only because of a sloppy shift on my part.
__________________
__________________
i didnt get a chance to ride it today but i'll put some blue locktite on the shiftlever i think that may have been the culprit
