Oil drain bolt
Old 04-08-2009, 11:38 PM
larazauk's Avatar
larazauk
larazauk is offline
Default Oil drain bolt
Feel like a dummy asking this but the diagram in the service manual is not very clear.
Is the engine oil drain bolt on my 07 the one that is facing you on the left side of the engine by the rubber bung on the frame? if so do you hav to remove the bung to get a socket & ratchet on it?
Old 04-09-2009, 12:08 AM
rdondes's Avatar
rdondes
rdondes is offline
What year and model motorcycle do you have?
Old 04-09-2009, 12:12 AM
larazauk's Avatar
larazauk
larazauk is offline
07 street bob
Old 04-09-2009, 12:25 AM
rdondes's Avatar
rdondes
rdondes is offline
I am looking on Pages 80 and 85 of my Dyna 2007 Owner's Manual. Under the transmission on the left side, you will see two drain plugs. The drain plug for the engine oil is the one that is towards the rear of the bike (in the oil pan under the transmission - Pg. 80). The plug in front of that plug and a little inboard, is the transmission drain plug (Pg. 85). You shouldn't have to remove anything to get the drain plug out. Make sure the bike is standing upright when you change the oil. Either on a jack, or with a 2x4 under the sidestand.
Old 04-09-2009, 12:57 AM
larazauk's Avatar
larazauk
larazauk is offline
Thanks for that, got it
Old 04-09-2009, 06:14 AM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
It's the drain bolt on the left side...
green hd
10-30-2012 07:45 PM
94DYNADOG
08-04-2012 12:08 PM
rattlebones
02-23-2010 03:41 PM
Ohiobellboy
Oil Archive (no new posts)
01-16-2010 04:40 PM
Westwood
05-16-2007 11:00 PM
Quick Reply: Oil drain bolt
