Oil Archive (no new posts) An archive of oil related questions and comments.
89 FLHTC Oil Plug?
Old May 12, 2007 | 08:45 PM
Westwood's Avatar
Westwood
6th Gear
Default 89 FLHTC Oil Plug?
Can anyone tell me where the oil plug is to drain an 89 FLHTC? I see one plug directly under the engine, which Iunscrewed and nothing much came out.and another under the back right side of the motor?
Jack
Old May 16, 2007 | 10:17 PM
liv2hunt's Avatar
liv2hunt
Default RE: 89 FLHTC Oil Plug?
I have a 2001 Heritagethe oil drain plugis on the right side of the bike its in the frame you will see the bolt. The trans drain is up between the shocks
Old May 16, 2007 | 11:00 PM
texas tom's Avatar
texas tom
Softtail is different from flt`s you probably pulled the tranny plug the oil plug is on left side and points out or parralel to the engine pan ,or at least its that way on newer flht`s it should be a 5/8 bolt that also has a allen socket in it.
PhatBoyHigh
Nov 25, 2015 11:11 AM
barrywilson
Nov 23, 2014 03:58 PM
jtsteiert
Mar 3, 2014 08:36 AM
rattlebones
Feb 23, 2010 03:41 PM
rolivarez
Aug 12, 2008 05:53 AM
