Sissy bar installation
Old 08-08-2009, 08:45 PM
prouddawg's Avatar
prouddawg
prouddawg is offline
Default Sissy bar installation
I have a 09 FXDC and I am wanting to put a sissy bar on with detachable sideplates. My question is do I have to do a turn signal relocation for the side plates? Thanks for your help!!
Old 08-08-2009, 10:00 PM
HD 472's Avatar
HD 472
HD 472 is offline
Yes you do...
Old 08-08-2009, 10:06 PM
bberck's Avatar
bberck
bberck is offline
You dont have to relocate them but you have to install a different mount for them.
You need this for the front mount 53961-06
and to replace the mounts for the turn signals you need 53968-06B (I think the number has been changed to 53968-06C but the website still shows the B)
Old 08-08-2009, 10:16 PM
70mach1's Avatar
70mach1
70mach1 is offline
Default Kury raptor
Not trying to interup but I have a new in the box Kuryakyn raptor sissy bar I bought for my 07 low rider that will fit your dyna .
I,m willing to sell it for $130' I paid almost $170. with shipping .
Let me no . Thanks,,,
Old 08-08-2009, 10:26 PM
RonnR's Avatar
RonnR
RonnR is offline
They call it a relocation kit, but it relocate out so the detach space can fit in..
Old 08-08-2009, 10:35 PM
xbox's Avatar
xbox
xbox is offline
I got my parts to do mine, question:
How do the turn signal wires detatch? Are they quick detach under the fender?
or do they need to be cut?
This easy to do your self?
Old 08-08-2009, 10:43 PM
bberck's Avatar
bberck
bberck is offline
They detach at the brake light but the kit has you cut them so they will fit through the new stalks.
It can be a pain getting the wires pushed through but its not a hard job.
Old 08-23-2009, 04:54 PM
pewterdenimbob's Avatar
pewterdenimbob
pewterdenimbob is offline
2nd Gear
Default wide tire
Any idea if the 53968-06 "relocation kit" will work with the 180 wide tire kit?
Old 09-19-2009, 10:51 PM
zomar's Avatar
zomar
zomar is offline
Stage I
I am wondering the same thing as the 180 mm Wide Tire Kit #43768-06 has a note that says if a Dyna Saddlebag Kit has been previously installed then you can discard the rear fender brackets etc. and only use the tire in the kit. Seems like a waste to buy the kit, should have just purchased the tire #43197-04A. Anyway, this note is very vague as I have a detachable sissy bar and saddle bags that are useing the #53968-06 docking hardware. The 53968-06 fender bracket is tight to the fender but not as tight as the included fender brackets. I am not able to use the included fender brackets as the rear bolt location isn't threaded so I may need to modify the existing fender brackets. Has anyone installed the wide tire kit and left the 53968-06 fender brackets as is?
Old 09-20-2009, 10:28 AM
RonnR's Avatar
RonnR
RonnR is offline
I had both, the widetire kit, and the relocation kit installed before delivery..
I was at the time led to believe that the 180 kit was necessary if I wanted the tire, however even tho it may be a good idea, it is not necessary..
Quick Reply: Sissy bar installation
