Spark Plug help
Old 03-09-2010, 04:47 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Jb...you can try emailing them.
Old 03-09-2010, 06:23 PM
wlbowers's Avatar
wlbowers
wlbowers is offline
Originally Posted by jb1023
So does anybody know if the NGK part # for a 2005 Dyna is the same as a 2007? I ask because their web site only goes up to 2005.
Starting in '06 the plugs are used by the ecm as a combustion sensor through ion levels. The wrong wires or plugs and you could throw a code.
I'd email them before I bought.
Old 03-09-2010, 07:03 PM
togfish's Avatar
togfish
togfish is offline
Wink
The HD plugs for EFI engines are made by Champion but are proprietary to Harley. They have a specific resistance that works along with a tap on the coil primary winding to send a signal to the ECM in the case of detonation. They reccomend not even using SE plugs with this setup. The stock plugs are only about $5. How do I know? I stayed at a Holiday Inn Express last night.
Steen
02-20-2016 07:26 AM
RodeoHard
EVO
19
04-13-2011 07:00 AM
Quick Reply: Spark Plug help
