06 Street Bob cuts out
Old 06-05-2010, 10:35 PM
StreetBobTeacher's Avatar
StreetBobTeacher
StreetBobTeacher is offline
Default 06 Street Bob cuts out
I bought an 06 Street Bob w/Screaming Eagle pipes late in the season last year. Had to put a fuel pump on it to get it running and initially it ran pretty well, but as time went on it started running rough, cutting out, cracking, popping and killing out at low rpm. Took it to the dealer and they said it had a service bulletin for the fuel injectors so they put in new injectors and tuned it. Don't think it made a bit of difference. Is the worst when it is cold. But even cuts out and kills after a short stop when the engine is warm. I have a friend who thinks a Power Commander will solve the problem. Anybody got any ideas? I hate being embarrassed when I go to take off and it coughs and sputters and sometimes even kills!!!
Old 06-05-2010, 11:05 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Do you lose total power? Lights, ignition... if so, I'd check the ignition switch connector underneath the dash. My '07 WG had an issue where I was riding ~65mph through the country and it cut out completely twice. The ignition switch connection was a lil wet. dried it, added some dielectric grease and all's well.
Old 06-06-2010, 08:01 AM
sniper77's Avatar
sniper77
sniper77 is offline
I don't think a power commander will address what's wrong.
Start with the basics; check your battery connections, make sure they are tight. Check your spark plugs and make sure your spark plug wires are securely connected to both the coil and the spark plugs. check your air cleaner and clean or replace it. Buy a can of carb cleaner and with the bike running, spray the carb cleaner behind your horn where the intake manifold meets the cylinders. If the engine rpms increase, you have a manifold gasket leak and new gaskets will fix it.
Let us know the results.
Old 06-06-2010, 08:13 AM
fireman36's Avatar
fireman36
fireman36 is offline
i agree with sniper, it doesnt sound like a problem a PC will fix..... you have something esle going on , check all those things above and go from there
Old 06-12-2010, 02:10 PM
StreetBobTeacher
Thanks for the input. It doesn't seem to be an electrical problem. I don't loose lights, etc when it cuts out. And I have replaced spark plugs and made sure the wires are connected tightly. Will give the carb cleaner a try.
Old 06-13-2010, 09:12 PM
man4mopar's Avatar
man4mopar
man4mopar is offline
Check the wires going to the injectors. It is a known issue that the loom doesn't have enough play for the wire with engine movement. The wire has broken inside the insulator so they look fine and work ok at times and then fail at others, example idles fine but when under load will cut out etc and not always.
Mine broke right inside the connector, here is a link.
https://www.hdforums.com/forum/dyna-...you-later.html
Old 06-13-2010, 09:21 PM
HDTech74's Avatar
HDTech74
HDTech74 is offline
Is it running on one cylinder when it starts to run like crap.
I've encountered this problem a few times on FXDB's.
the wires going into the injector plugs were partially broken.
Have you tried a wiggle test?
Old 06-13-2010, 10:47 PM
StreetBobTeacher
Good information to know. It runs pretty well at higher rpms, but cuts out and kills on idle and low rpm. Not all the time, but enough to be embarrassing. Have alot of popping etc. when you let off the gas.
Old 06-13-2010, 11:47 PM
FXDFan's Avatar
FXDFan
FXDFan is offline
Start the bike up in the garage, nice and dark, and spray water on your plugs. Mine was doing very much the same thing, the plug wires, while snugly in place, were arcing, giving poor connectivity. New plug wires and bingo, good as new.
Daehawc
07-30-2016 07:13 PM
Harleyonthebrain
Exhaust System Topics
06-24-2011 07:11 PM
12pack
21
12-08-2009 08:53 AM
elwoodto
03-26-2009 07:40 PM
harrygart
12-15-2007 05:32 PM
Quick Reply: 06 Street Bob cuts out
