Check engine light/ Regulator test
Scenerio, 07 street bob. Ignition on check engine light doe its thing A few seconds after it goes out it comes back on for a few seconds then goes out and stays out. Go down the road and the light comes back on. Stop, shut it down turn it back on same thing. Continues so since we have to get home dennis ignores the light. Battery light comes on We stop. no start battery id dead. Jump the bike and get home. Only dtc is low battery voltage. Charged battery checks out good. I suspect voltage regulator, only problem is that HD manual does not tell you how to static test the VR on an 07. Says you need the electrical manual. My 99 sporty did the same thing, (minus the computer chit since it doesn't have lights like that). That manual tells you how to staic test the regulator. Anyone know how to test it on the newer models. And yes we have checked and cleaned all battery cable connections. At this time the battery is charged and reinstalled. Ignition on you get the check engine light. Goes out and doesn't come back on. Start the bike, all is good. Somehow it might be cured but we would all fell better if we coud check the vr. Might be that the check engine light comes on before the system records low battery voltage condition. Any thoughts would be appreciated as well as steps to static test the VR Thanks
How to check diagnostic codes
https://www.hdforums.com/forum/dyna-glide-models/264270-check-engine-light.html
https://www.hdforums.com/m_2293229/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/139328-identify-trouble-codes-and-clear-them.html
https://www.hdforums.com/forum/dyna-...06-2008-a.html
Received 4,312 Likes
I had a similar problem on my 08.
Got the Electrical Manual out, turned to the Charging System section.
The paragraph titled: Wiring says...
"The stator & battery connector plugs & socket connections must be clean & tight. See Figure 1-12. Check for corroded or loose connections in the charging system."
The next paragraph, titled: Voltage Regulator Inspection says...
"The VR must have a clean, tight connection for proper grounding. Check by using an ohmmeter with one lead on a known good ground, like the negative battery cable, and the other on the regulator ground lead."
So... while the battery was on the trickle charger, I started checking out the wiring.
Figure 1-12 shows the circuit running through the 40 amp MAXIFUSE. It was good, so I moved on checking the connections.
I was checking the continuity using a volt meter between the battery side of the VR plug & each battery cable. I kept getting sporadic readings so I got a small round file to clean the inside of the terminal ends. This is what I found:
I replaced the terminal connectors, reinstalled the battery & it was up & running.
The rest of the Charging System section involves testing the entire system as a whole.
The voltage regulator... "is a series regulator. It combines the functions of rectifying (changing AC to DC) and regulating."
The paragraph titled: Current and Voltage Output Test: Using Load Tester says...
“1. Connect load tester... -/+ to battery... induction pickup over the positive regulator lead.
2. Run engine at 3000rpm. Increase the load as required to obtain a constant 13v DC.
3. Current output should be 35-40 amps.
4. After removing the load read the Load Tester voltage meter.
4.a. If voltage to the battery is not more than 15v DC, voltage output is within specifications... bla, bla, bla.
4.b. If voltage is higher, voltage regulator is not functioning (regulating) properly.”
Reviving this 10 yeaor old post...
Attachment 560659
I replaced the terminal connectors, reinstalled the battery & it was up & running.”
Anybody know where I can find those crimp terminals? Thanks...
Attachment 560659
Attachment 560659
