Vance & Hines side shots dyno numbers?
Old 07-14-2010, 12:59 AM
n0code's Avatar
n0code
n0code is offline
Default Vance & Hines side shots dyno numbers?
I've searched the forum for a good ten minutes and have not found anything conclusive the performance of the Side Shots on a 96 Twin Cam.
I found this thread on the sportster forum on the performance on a 1200cc sporty.
https://www.hdforums.com/forum/sport...n-results.html
The thread reports 79.87 HP and 78.57 Torque...
I have a stage one setup with a D&D fatcat dynoed at 75.39 hp and 88.08 torque.
I'd like to know what difference to expect with the side shots. I'm still a newbie but I do understand that 2-1 will create more torque.
But man... do side shots look sexy on a black dyna!
Old 07-14-2010, 10:57 AM
KAUFMANSM's Avatar
KAUFMANSM
KAUFMANSM is offline
I'll let you know next week. I'm having side shots, a RSD air cleaner and a SERT installed and Dyno tuned.
Old 07-14-2010, 11:25 AM
paul s's Avatar
paul s
paul s is offline
I had the Sideshots w/BCT QQ's, the sound and performance was great. I switched to the Supermeg and lost a few ponies with 20 disc closed, I ended up getting the open cap and I feel a little more power in the bottom end now. The Sideshots are good pipes.
Old 07-14-2010, 01:52 PM
Goddahavit's Avatar
Goddahavit
Goddahavit is offline
I had V&H slop ons with BCT thunder baffles, and then switched to the sideshots, it definitely lost some bottom end.
I now have the qq baffles in and its still not as good as the stock head pipes and slip ons/bct combo, but love the looks.
Old 07-14-2010, 02:04 PM
SBRob's Avatar
SBRob
SBRob is offline
Received 4,097 Likes on 1,635 Posts
Here's my dyno sheet with V&H Sideshots and V&H quiet baffles....
Old 07-14-2010, 07:10 PM
KAUFMANSM's Avatar
KAUFMANSM
Hows the sound with the standard baffles?
Old 07-14-2010, 07:31 PM
nkauf21's Avatar
nkauf21
nkauf21 is offline
Good, but loud.
Old 07-14-2010, 08:30 PM
MarineMike's Avatar
MarineMike
MarineMike is offline
I know what you mean, I had the SEII slipons and when I switched to the sideshots i lost some on the bottom end (seat of the pants feel). But for me, the looks out way the couple of horses I lost.
Old 07-14-2010, 08:55 PM
16_Tri-Glide's Avatar
16_Tri-Glide
16_Tri-Glide is offline
I have V & H short shots on my 09 SB with a Stage 1 A/C, SE 204 cams, and a PC5. Right now my bike is running a little bit rich and needs to be retuned, but it is at 82.5 hp and 91 ft lbs of torque.
Old 07-14-2010, 09:30 PM
n0code's Avatar
n0code
n0code is offline
And here I thought that 2-1 were the end all of pipes. Those pipes are real impressive.
They look especially great on the 09 bobs, the gray motor and black pipe make a great contrast. Anyone who is still bath mouthing their 2009s better think twice!
Quick Reply: Vance & Hines side shots dyno numbers?
