V-Rod Rear wheel on an 06 Dyna
Old 12-30-2010, 08:29 PM
Swede405's Avatar
Swede405
Swede405 is offline
Default V-Rod Rear wheel on an 06 Dyna
Anybody tried this or know if it would work. The '02-'07 V-Rod wheels are 18x5.5 rim with a 1" axle, all of which should fit, but I'm not sure about the spacers, rotor, pulley and everything else. The wheel install kit from Harley (link) is the same for both bikes, but I don't think that guarantees anything.
Old 12-30-2010, 08:32 PM
bberck's Avatar
bberck
bberck is offline
I have seen it done but can't answer the other questions.
Old 12-30-2010, 09:29 PM
MDStbob's Avatar
MDStbob
MDStbob is offline
I've been wondering this for a while. I've had a rear vrod wheel for a while
Old 12-31-2010, 12:08 PM
filthpig's Avatar
filthpig
filthpig is offline
I did it, was not easy. The pulley side bolt pattern does not match up with standard pulley. I had an adapter plate made. The hub is wider so stock brake does not work ,I had an oversized swingarm to use.
Attached Thumbnails V-Rod Rear wheel on an 06 Dyna-2010-013.jpg   V-Rod Rear wheel on an 06 Dyna-2010-012.jpg
FXD_noob (01-20-2021)
Old 12-31-2010, 03:43 PM
Swede405's Avatar
Swede405
Swede405 is offline
Thanks filthpig. Sounds like a little more involved than what I was planning. What bike did you do it on?
Old 12-31-2010, 04:01 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
Originally Posted by WS6 Formula
Here's a V Rod set up on a Dyna.
Old 01-01-2011, 02:39 PM
filthpig's Avatar
filthpig
filthpig is offline
mines on 08 fxdc.....the biggest problem was the pulley. I had thought of going to a brake/pulley combo, but the idea of the brake heating up the belt just does not appeal. The sprocket/chain combo was also not an appealing option for me. This is what I came up with.
I had additional holes drilled and taped into the hub, then made the spacer plate.
But, I have since decided that I need a bigger pulley on the rear so I have a 70tooth blank I am going to fit to the plate. I just am not happy with where the wheel ended up in relation to the swingarm, there is less than an eigth of an inch between the two. So this means a new longer belt, might as well put on a bigger pulley. Having ideas of extending the swingarm an inch or two as I only have about half an inch axle play with the current setup.
It simply never ends........
Attached Thumbnails V-Rod Rear wheel on an 06 Dyna-vrod-001.jpg   V-Rod Rear wheel on an 06 Dyna-vrod-004.jpg   V-Rod Rear wheel on an 06 Dyna-vrod-006.jpg
theduroche
10-25-2018 12:43 AM
machm1969
01-02-2014 07:39 PM
filthpig
09-02-2010 03:23 PM
filthpig
01-24-2010 07:08 AM
hec4sc
12-30-2006 03:25 AM
Quick Reply: V-Rod Rear wheel on an 06 Dyna
