Pipe wrap recommendations.
Heatshield Products Lava Wrap Exhaust Wrap 2000 Degree
Lava Wrap is the superior choice for your heat shielding needs. Made from crushed volcanic rock, Lava Wrap not only has a sleek look similar to carbon fiber, but is also twice as durable. Exhaust wraps help to retain heat in your exhaust system, which increases horsepower while reducing radiant heat damage. By wrapping the header and exhaust system it maintains hotter exhaust gases, decreases the density, and allows the exhaust gas to exit the system faster! Greater exhaust scavenging is produced and lowers intake temperatures: that equals more horsepower. Exhaust wrap can be fastened with Thermal-Tie, hose clamps, or wire."
It's 1/16th thick. I got a buddy to hold the pipes while I wrapped then, it helps.
