Deltran Battery Tender Plus Question
This past week, as I always do when not riding, I had my Deltran Battery Tender Plus hooked up to my 2007 FXDC Super Glide Custom. Yesterday morning, before I went for a 200 mile ride, I noted that the Battery Tender Plus was showing a solid GREEN indicator, indicating that the battery was fully charged. I went on the 200 mile ride. Bike started fine over a dozen times during the ride.
I come home after the 200 mile ride. Hook up the Deltran Battery Tender Plus like I always do. The indicator showed solid red, which it normally does, before going to blinking green after about 10-15 minutes and then solid green when fully charged. That was yesterday.
Today, at 2pm, about 20 hours after hooking up the Battery Tender Plus, I went out to the bike to check on something. The Battery Tender Plus was showing an indicator of solid RED. The Battery Tender Plus' connections to the battery were tight, the 7.5A inline fuse on the Battery Tender Plus connection harness was fine, the battery terminals were clean, all connections were fine - but it appears that the Battery Tender Plus cannot charge my battery. When I started the bike, it cranked as if the battery were low. I ran the bike for a minute, shut it down, re-started it, and the battery cranked stronger than on the initial cranking.
Is this a battery problem? Or a Battery Tender Plus Problem? Suggestions?
Thanks,
Richard
Thanks,
Richard
Received 47,791 Likes
Thanks...too bad I don't have a multi meter. Have never needed one. I'll see how the Deltran Battery Tender does now while hooked up to my car.
You're right. Even though I've been out of work for 2 years, and am in survival mode, a multi-meter is in fact only $10 at Radio Shack.
I now have the Deltran Battery Tender Plus hooked up to my car battery (1999 Ford Crown Vic) and after 30 minutes the blinking green light (indicating 80% charge) has not come on. I think the Tender is bad. However, I'll wait another hour to see if the blinking green light comes on. My car battery is only 3 months old and starts the car no problem.
