Raked triple tree for my Dyna?
Old 03-31-2011, 12:22 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Originally Posted by dyna rider
Stay with the stock rake as changing it can lead to lots of unforeseeable problems.
Wouldn't that negate what the OP wants to do? It's not like this mod hasn't been made thousands of times since the 60's? Yes it should be done correctly but advising the OP to moreorless not change anything on his bike when you're not flippin the bill is a bit wrong. Heck, didn't they used to just cut the neck and reweld it by eye back then? (before my time). I don't remember ever hearing about people dying after that mod was made.
It might be better advised to seek the knowledge of a reliable indy shop the OP trusts to make such a mod possible without any dangerous side effects.
Also, there are 'chopper" kits available as a bolt-on. www.chopper-kits.com and www.seegercycle.com Worth a look especially since your bike is 39mm so they have it all figured out for you.
[edit] I'll still never understand why the forum software flags the name "j o r d a n". It's quite funny.
Old 03-31-2011, 02:30 PM
jordanball33's Avatar
jordanball33
jordanball33 is offline
me either man, its hell trying to give someone my email address or pay pal or anything on here.
Old 03-31-2011, 04:11 PM
dynamiamiflo's Avatar
dynamiamiflo
dynamiamiflo is offline
Hey Vic, well stated and much appreciated. Went on the Seegercycle and I am calling them to see what they can do, but your absolutely right it should be quite doable. I also spoke with my mechanic and sounds feasible as well. Also checked a kit out at Headwinds that looks similar to the seegercyle but a little less expensive, so will be investigating both. It appears I can rake the triple tree 3 or 4 degrees without extending the tubes and pretty easy change out. Thanks for all the help, this board rocks!!!
I guess J o r d a n is a bad word for the moderators!
Old 03-31-2011, 05:12 PM
Dingobob's Avatar
Dingobob
Dingobob is offline
Search for traveller's 05 fxd, it's sold now but there is plenty of threads on it. He had 3 degree trees and 3 degree cups and handling was fine. I have used 3 degree trees before without issue but had wobbles over 70 mph with 5 degree on a softtail
TOE_CUTTER
11-14-2017 07:24 AM
CountryPunk
07-10-2009 09:44 AM
Jinxie
02-17-2009 12:21 PM
Swamphunter
09-02-2007 09:18 PM
harleyvato1963
08-27-2007 06:29 PM
Quick Reply: Raked triple tree for my Dyna?
