Programming/ Using Manual Security Code (Both FOB'S)
Old 04-26-2011, 11:34 AM
'10 Wide Glide's Avatar
'10 Wide Glide
'10 Wide Glide is offline
Default Programming/ Using Manual Security Code (Both FOB'S)
Alarm_Info.zip
To verify your PIN code, proceed as follows with the FOB present..
Turn ignition on-off-on-off-on.Then hit the left blinker button twice-then the right button once *. You should get the current pin number displayed in the odometer window.
Don't waste any time doing this or it will not work.
*With a button fob system you must hit the button on fob twice instead of hitting right signal to enter new code. Same to find existing PIN. Button fob twice instead of right signal.
Let's assume for simplicity that your code is set at 31313 and you wish to use the manual disarm of the security system using the directional switches as if you lost your fob and cannot disarm the system.
Your security system will disarm the bike and it cannot be started without deactivating the system first.
This applies to systems using the button type security fob only. See further down the page for later button less models.
If you are unsure of what the manual code is refer to the top of this page or check with your dealer and set one if it has not been set by them. Failure to set a manual code may require a replacement of the TSSM should a problem arise and they come at a healthy price.
Again this is based on your code being 31313 just to make it easier to understand.
1. Turn the ignition to Accessory.
2. Press both turn signals. (security light should flash rapidly)
3. Press left turn signal button 3 times. Press right turn signal button 1 time.
4. Press left turn signal button 1 time. Press right turn signal button 1 time.
5. Press left turn signal button 3 times. Press right turn signal button 1 time.
6. Press left turn signal button 1 time. Press right turn signal button 1 time.
7. Press left turn signal button 3 times. Press right turn signal button 1 time.
Security light stops flashing and security system is disarmed.
If you've changed the number, use your new number instead of 31313.
Button less fobs (Smart FOB)
To view how to deactivate the security system using the manual PIN codes, read here.
Manual Alarm Disarming Procedure
To view/change the PIN number follow this procedure, but read and understand it first, then see the note at the bottom.
1. Select 5 digit code (1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 2 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
NOTE
The key to doing this proceedure is to turn the ignition switch on/off/on/off/on and use the left directional 3 times then the right just once and do it all in TWO SECONDS or it will not work.
Also on new installations, the dealer has to program the fob using the bar code for it to work.
Old 04-26-2011, 11:50 AM
hd_sob's Avatar
hd_sob
hd_sob is offline
i've never used my fob. had it for 5 years, dunno if it even works...
Old 04-26-2011, 11:55 AM
'10 Wide Glide
Do you use your bypass?
Old 04-26-2011, 12:02 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
i've never used the alarm/fob thing, period. never saw much point in it. if someone wants it, they'll take it, whether it starts or not. i do use the fork lock, as useless as it is. don't ask me why...
Old 05-02-2011, 10:34 AM
XSKIPRO's Avatar
XSKIPRO
XSKIPRO is offline
How do you change your pin once you figure out what it is?
Old 05-02-2011, 01:28 PM
oldrocker's Avatar
oldrocker
oldrocker is offline
1st Gear
Default 8241356]Alarm_Info.zip
Thanks for the write up on the HD "smart security system". I don't have the same bike but I do have the fob style system in a 2011 FLTRUSE. I've been running without a manual disarm code because I didn't have the time nor patience to make sense of what the owner's manual was telling me to do. I printed out your instructions and bang, first time right in and stored. Thanks, your work sure helped me out!
Old 06-23-2017, 10:48 AM
Tareq Abdulla AbdulAziz's Avatar
Tareq Abdulla AbdulAziz is offline
Stage II
Alarm_Info.zip
NOTE
Dear Sir
What if I lost the key fob and I don't know the security code.
Regards;
Old 06-23-2017, 03:26 PM
Smogbob's Avatar
Smogbob
Smogbob is offline
Originally Posted by Tareq Abdulla AbdulAziz
Dear Sir
Regards;
You will have to take your ride to your Harley dealer to get new fobs programmed, but normally you should have 2 fobs with the ride.
Old 07-11-2018, 02:40 AM
2002deuce's Avatar
2002deuce
2002deuce is offline
Stage II
where is or How to bypass? 02....
Old 07-11-2018, 09:49 AM
Jay Guild's Avatar
Jay Guild
Jay Guild is offline
You'd be the first set of instructions. I'm not sure that year had FOBs yet but the default factory code is all 1s. If it has been changed and you don't know the code, take it to a dealer.
Hero
09-13-2023 02:15 PM
Scudda
02-09-2020 10:53 PM
jimjim
03-30-2017 03:40 PM
dustin1014
01-04-2014 03:09 AM
0Nightster7
06-28-2010 07:32 AM
Quick Reply: Programming/ Using Manual Security Code (Both FOB'S)
