Securit Code
Old Feb 5, 2019 | 08:00 AM
Scudda's Avatar
Scudda
Default Securit Code
Hi All,
One thing I have never done or checked on My 05 Fatboy since I have owned it was to either check or set the security pin number. The bike has the factory security system with the push button FOB.
Does anyone have the procedure to check and reset the code?
Old Feb 5, 2019 | 09:13 AM
XARAN's Avatar
XARAN
As long as you have a working FOB it is an easy procedure.
PRE 2014 Harley Davidson Motorcycles
Setting or Changing Your Security System Alarm Override PIN
(scroll down to see how to use the pin code to override the security system)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press left turn signal switch 3 times
4. Press RIGHT turn signal switch one time and release
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing
5. Enter first digit of the new PIN by pressing LEFT turn signal (x) times
6. Press RIGHT turn signal 1 time and release. The second digit will be flashing
7. Enter second digit of the new PIN by pressing LEFT turn signal switch (x) times
8. Press RIGHT turn signal 1 time and release. The third digit will be flashing
9. Enter the third digit of the new PIN by pressing LEFT turn signal (x) times
10. Press the RIGHT turn switch 1 time and release. The forth digit will be flashing
11. Enter forth digit of the new PIN by pressing LEFT turn signal switch (x) times
12. Press the RIGHT turn switch 1 time and release. The fifth digit will be flashing
13. Enter the fifth digit of the new PIN by pressing LEFT turn signal (x) times
14. Before the module rearms, turn ignition key to OFF to store the new pin in the module
Using the Security Alarm PIN Override to Start Your Harley Davidson (pre 2014)
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window
2. Enter the first digit of your PIN by pressing the LEFT turn signal switch (X) times
3. Press the RIGHT turn signal switch 1 time to move to the next digit
4. Enter the second digit of your PIN by pressing the LEFT turn signal switch (X) times
5. Press the RIGHT turn signal switch 1 time to move to the next digit
6. Enter the third digit of your PIN by pressing the LEFT turn signal switch (X) times
7. Press the RIGHT turn signal switch 1 time to move to the next digit
8. Enter the forth digit of your PIN by pressing the LEFT turn signal switch (X) times
9. Press the RIGHT turn signal switch 1 time to move to the next digit
10. Enter the fifth digit of your PIN by pressing the LEFT turn signal switch (X) times
11. Press the RIGHT turn signal switch 1 time to move to the next digit
12. Press the RIGHT turn signal switch 1 time and the security system alarm is turned off.
Its also in the owners manual or here is a link
https://www.cyclefish.com/forums/top...g-pin-override
Old Feb 5, 2019 | 12:50 PM
Scudda's Avatar
Scudda
Thank You!!
Old Feb 5, 2019 | 01:25 PM
hattitude's Avatar
hattitude
Just curious..... Why would you need a working FOB to be present?
I believe a 2005 will have the active style security system.... On an active system, with a push button FOB, the FOB doesn't communicate with the TSSM unless you push the FOB button. So as long as the security is disabled, the TSSM wouldn't know if a FOB was present or miles away....
And on step #14 - "Before the module rearms, turn ignition key to OFF to store the new pin in the module". On an active security system, the module won't rearm unless you push the FOB button.
Is this the procedure for a passive security system (no button FOB) or the active security system (FOB w/button)...?
What am I missing....?
Old Mar 17, 2019 | 04:26 PM
Sogshore's Avatar
Sogshore
Stage II
Default I need help
I feel as if I have tried every option that I have found online to get the “enter code” issue resolved. About to find a trailer and take to dealership... any help would be great.
Originally Posted by Scudda
Hi All,
Old Mar 17, 2019 | 04:39 PM
Hoginedgewood's Avatar
Hoginedgewood
Hi All,
do you have the owners manual?
yours should have a button on the remote, some body was nice enough to get directions for a proximity remote I believe.
Old Mar 17, 2019 | 04:53 PM
barneyboy's Avatar
barneyboy
Procedures vary by model year. Year & model would be helpful.
Old Mar 17, 2019 | 05:07 PM
Sogshore's Avatar
Sogshore
Stage II
Sorry 2011 fat boy lo
Old Mar 17, 2019 | 06:06 PM
barneyboy's Avatar
barneyboy
Not sure what you're trying to do, change the PIN, or override the security system by manually entering the PIN, but both procedures are explained in the link in post #2, scroll down to pre 2014.
Old Mar 17, 2019 | 06:17 PM
Bone Doc's Avatar
Bone Doc
As an FYI to all that are unsure of the procedure; it is found in your OWNERS manual. Not the SERVICE manual, the OWNERS manual. If you don't have an owners manual for your model year bike, you can access it through the H-D Service Information Portal.
