quick remap question on EFI models, is it needed?
I have the stage 1 kit on my 07 SB. I am going back to stock pipes. I was told that a new map was loaded specifically for this setup. Do I need to take it back to the dealer to have it remapped? What kind of cost is there for this change? This is my first EFI bike, im kind of a n00b..
Thanks.
Thanks.
I guess the big question is what type of tuner did they/you use? SE pro tuner, PCIII, PCV, V&H fuel pak, etc. Some tuners like the pcIII are a piggie back which mean they are connected all the time and if disconnected it all goes back to stock so it would be as easy as disconnecting the piggie back unit. Other units like the SE pro tuner and many others re-calibrate the ecu and need to be adjusted when something is changed and it that case you would need a re-tune. If you just have a standard map and its not a custom done on a dyno you could just get another standard map for the new setup, if you have a custom tune you could still go back to a standard map but kind of throughing money out the window if you ask me. Can I ask why your going back to stockers?
If the stage one was put on by the dealer, they loaded a Stage I MAP to compensate for higher flow rate. You don't need to change this MAP, it won't hurt anything. Your mpg may drop. If you don't like how it rides, then you can decide if you want to remap and by what method. I would be surprised if you notice any difference.
Dealers often charge over $150 just to remap the ECU.
If the bike was dyno tuned, there is still no need to remap unless you want peak performance, that last 3%... so just ride it and see what you think.
I am unsure of exactly what was done, I am owner 3 of the bike (with 7800 miles). Owner 2 only put about 2k miles on it and had no idea. Owner 1 worked at a HD dealership and I was told by owner 2 it was "done right" so I can only assume its whatever the dealership would do. I will swing by the dealership and if they have any records on hand that would tell me what they actually did to it.
As for why I would go back to stock pipes. The V&H pipes are way to loud for my taste.
Sounds like you plan of goin gto dealership is your best bet. as The previous poster said you could swap out pipes and leave it alone but it may not run all that great but you could try it and see what you think and go from there.
