streetbob trees to fat bob trees
Hi, I would like to know if anyone has replaced their 2010 streetbob triple trees with fatbob triple trees?. what's involved and can it be done. I am thinking of changing my bars to 12 or 14 apes, and though that changing the trees would give me a wider choice of bars. Is the rake or trial changed if so how much? also I am keeping the standard front wheel. If anyone has done this could you please post a pic so I can see what it looks like before handing over heaps of coin. Thanks Gordo
There is no rake in the fatbob trees, but there is in the wide glide. You going to need a few things to complete the change over. There is plenty of post on here if you use the search function, i did just this a few days go...
If you want to keep your street bob sliders and tubes you will need to...
Space your rotor and/or brake caliper, and wheels. If you want to go with fatbob lowers your going to need the entire front end assembly, as it has dual discs and different calipers and possible a new master cylinder. Hope this helps in your search
Just did it
I did not change any of my brake components, don't know why you would have to change your master cylinder. I just swaped trees and used wide glide wheel and axle. As sombody stated above you can remove one disc from a dual disc wide glide hub and place a cover on.
I just installed Todd's 12" Strip Apes and switched from stock trees to Fatbob trees on my 06 Streetbob so I can run 150\16 white walls on the front and rear. As stated above your stock front wheel will not work unless you find a spacer for your brake disc and axles. There are some posts on here that list the dimensions for the spacers. I do not like the way the spacers look with the stock hub so I switched to a wide glide hub. The stock lower sliders will work perfect with a single disc wide glide hub and axle. I purchased a wide glide wheel from Black Bike and a wide glide axle online. The stock HD wide glide axle uses a 20mm and a 26mm axle spacer but for some reason the Black Bike wheel was 6mm off center with stock wide glide spacers SO I switched to two 7/8 inch spacers and problem solved. Had I used a OE Harley wide glide hub it would have worked fine with H.D. axle spacers.
I switched from a narrow 21" tire to a fat 150/16" and it handles rough roads much better. It feels harder to lean over. Looks mean as hell, picture coming soon.
not really, when going with a 16" rim your going to be running a fatter (high profile) tire, instead of a 21" with a low profile tire.
