twin cam still misfiring again, running on 1 cylinder...
Old 08-09-2012, 11:00 AM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
Gus -
Welcome aboard ...
Your '98 is an Evo motor (as opposed to Twin Cam, that first appeared in '99) ...
Based on your photo, I am thinking your bike must have a carb ...? In which case, none of the info on this thread will apply to you ... (except, the general advice with regards to ensuring good connections on wiring) ...
The Evos tend to sound a little more 'lumpy' than the Twin Cams ... what do you know about the bike ...? Does it have an aftermarket cam ...? Is it the stock carb ...?
It is possible the carb needs to be cleaned ... or there is some crud in the fuel filter, screen or fuel line that is causing the problem ... another possibility is a leak in the manifold gasket allowing air in between the manifold and intake port/head ...
You might get some better troubleshooting ideas if you post a description of your problem in either the Evo forum here ... https://www.hdforums.com/forum/evo-classic-models-84/
... or in the Engine/Fuel/Intake/Exhaust forum here ... https://www.hdforums.com/forum/engin...ke-exhaust-57/
Good luck ... and post the solution, if you figure out what the problem is ...
R/
'Chop
Old 08-09-2012, 11:28 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i would bet that you have an unpluged or loose injector
Old 08-09-2012, 04:53 PM
Gustoon's Avatar
Gustoon
Gustoon is offline
2nd Gear
Thanks for the warm welcome .
It does have a carb, and I'm fairly sure the cam is after market, screaming eagle??
I will have to check that out.
Not sure if this helps diagnose the problem, but if I start it from cold, I have to hold her open by the throttle (or choke) and it really smells , gassy.
I've been lent a compressor and will take the carb apart and fuel lines as you've suggested.
Ha ha I tried following the previous advice in this thread and applying it, needless to say I learnt alot and have a very clean set of electrics now.
Once again, I thank you for taking the time to get back to me, and hope to post the answer soon.
LOVE this site!
Old 08-09-2012, 06:50 PM
milesvdustin's Avatar
milesvdustin
milesvdustin is offline
What is that corroded connector with the terminal disconnected next to it in the first pic? Clean clean connections and a good solid ground is essential for your electronics.
Old 08-10-2012, 12:08 AM
Gustoon's Avatar
Gustoon
Gustoon is offline
2nd Gear
Thats the earth, the pic makes it look corroded, its actually grease.
Yep, got cleaning all sorted out, thanks
Old 08-10-2012, 09:34 AM
Gustoon's Avatar
Gustoon
Gustoon is offline
2nd Gear
Okey-Dokey, now after alot of prodding and poking, I do now have the answer, thank god!!!
I feel kind of stupid, but anyways here goes.
Partial blockage of fuel tap , got a clue when it ran ever so slightly better on reserve tank.
Although there was no sign that the rear spark plug wasn't working properley, eg: good color, I changed it and had an instant response.
Since the plugs were only changed less than 7k ago I was somewhat surprised :/
The upside is that I learnt a ton about my bike which this morning I didn't, and I have an electrical circuit you could perform heart surgery on
BIG thank you to all that gave me advice, and I'll promise to not bump threads that are a million years old
Peace
2004duce
Engine Mechanical Topics
06-11-2018 08:33 AM
Go Shovelhead Go
Shovelhead
10-28-2012 11:54 PM
DXHD $100
08-27-2012 03:22 PM
stinkfist
Exhaust System Topics
10-02-2008 12:53 PM
joker
09-27-2005 01:25 PM
Quick Reply: twin cam still misfiring again, running on 1 cylinder...
