idle between cylinders
gonna sound dumb, but my rear cylinder sounds like its running at a slower idle than the front. i haven't put a tach on, but regardless of cold/hot engine, the front cylinder runs at a steady clip (appx 1000), while the left is sort of syncopated, letting a big thud every so often.
the plugs are good, and no air leaks.
any suggestions where to look next?
RE: idle between cylinders
The two pistons in the two cylinders are attached to a common crankpin, so they must run at the same speed otherwise I'll buy it from you for any amount you name.
What you may be hearing may be the result of a few things, an intake leak, bad or intermittent plug, loose terminal on the top of the plug, bad wire or an arking/cracked coil.
You didn't say if you are carb or FI. It could also be a lean mixture causing what you are hearing (more than likely)
You could try switching the plugs to the opposite cylinders and see if the problem moves to the front cylinder.
Let us know.
Let us know.
i know they are running at the same speed, just don't sound like it. already tested the plug and terminal, didn't think of switching them. i'll give that a shot tomorrow. also look at the intake and wire/coil.
i'm running the flatslide carb, so wouldn't a lean mixture effect both cylinders?
Do the spray test around the rear cylinder intake seal and see what you get.
https://www.hdforums.com/m_85102/mpa..._/tm.htm#85102
By the way, don't confuse the rattle of the slide in that carb for engine noises.
