Intermittent rythmic tapping noise.
This has been a bad year for me so far.
2006 wide glide. 25,000 miles.
Now I have a tapping noise coming from the engine somewhere. The tapping is intermittent and taps about four to five times. Then is normal for about 4-5 seconds. I have used a screwdriver to my ear, but cannot seem to find the noise. It speeds up with engine speed and does it in neutral and in gear.
I already checked the compensator nut, and it was loose, so I pulled it and re torqued the bolt with red loc-tite per the manual. Noise is still there.
Any help is greatly appreciates. This is driving me insane.
if it speeds up with engine speed, its in your engine.
if it goes away after warm up its probably oil related, blockage in filter or to thick of oil.
if the sound comes from the top of the engine your luckey.... could be lifters,check oil level,oil pressure and filter for blockage ...worse case failing oil pump or failing lifters
bottom end, not so luckey..failing rod bearings,crankshaft bearings or connecting rod
or it could be as simple as a exhaust gasket....altho thats not a tapping noise but thats how my buddy described his "engine tapping noise" to me....check for leaks with a smoke
ive personally never had a bearing go in the bottom end.But if you increased engine speed your continous rythem would certianly be a faster contiunous rythem.
doesnt do it cold eh.... could still be failing lifters...just not oil related.
amsol is great oil, thats not your prob.but id still pull the filter and check it out
Old Road Toad
04-03-2014 01:31 PM
FXD_noob
01-24-2013 09:17 PM
AdrianVall
03-14-2009 04:05 PM
