Need Help Lacing 16 inch front wheel - Street Bob
Old 06-26-2012, 03:07 PM
DoomGloom's Avatar
DoomGloom
DoomGloom is offline
Unhappy Need Help Lacing 16 inch front wheel - Street Bob
Dropped my wheel off at local indy shop to have it laced up and trued.
16 x 3 inch front wheel - off of a Heritage Softail
2009 Dyna mid glide hub
Custom spokes cut by Buchanan Spokes for this application.
My indy is at a loss trying to lace the wheel, I even sent a close up of the same wheel that was done by a forum member here......
Is there a special lacing pattern, or should they be using the same lacing pattern as the original 19" wheel?
Thought about sending him the lacing instructions for a 48 Sportster front wheel, because it is the same size wheel and similar hub, but the 48 only has 36 spokes.........
Any help would be greatly appreciated.
Old 06-26-2012, 05:13 PM
wag_oh_neer's Avatar
wag_oh_neer
wag_oh_neer is offline
Well I got it figured out, the only deviation from the stock pattern is when installing the spokes into the hub. According to the manual: "Insert one short head spoke into any bottom flange hole and swing it clockwise. Insert a long head spoke in the next hole to the left of the short head spoke. Swing the long head spoke counterclockwise over the short head spoke. Find the hole in the upper flange directly above the two spokes just inserted. This hole uses a long head spoke." I had to use a short head spoke in this hole. Other than that just follow the directions in the manual for lacing a 19" wheel. Thanks to those that posted, as soon as I get the bike back together i'll try and post some pics(hopefully by this weekend).
Old 06-26-2012, 05:15 PM
AFMM3's Avatar
AFMM3
AFMM3 is offline
I would think it might be closer to the lacing pattern of a 16 inch wheel. But then again, that might still be the same as the 19 incher. You could lace it yourself, take your time and take it to your Indie for trueing and mounting/balancing. I almost went this exact route on my kid's Nightster but eventually just put a Fat Bob front end on it.
Old 06-26-2012, 07:01 PM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
wag oh neer - bike looks great with the 16" in front ...
DoomGloom - did you get it figured out ...?
R/
'Chop
Old 06-26-2012, 07:45 PM
wag_oh_neer
Thanks Surfor, it rides better than it looks too.
AFMM, you have to use the 19" pattern because its an inside lace hub, not a standard wide glide hub.
Old 06-26-2012, 08:49 PM
DoomGloom's Avatar
DoomGloom
Thumbs up
wag_oh_neer, Thanks for the repost of the lacing pattern! Im gonna get over to my indy tomorrow with the new plan....Ill take some pics when its done......
Old 06-26-2012, 09:01 PM
SuperFastGlide's Avatar
SuperFastGlide
SuperFastGlide is offline
looks great!!! luv my 16 as well
Old 06-26-2012, 10:35 PM
Lone Watie's Avatar
Lone Watie
Lone Watie is offline
You guys are teasing me with the laced wheels for my next off season. Time to start shopping now, though. The list always grows and never ends.
Old 06-26-2012, 11:00 PM
slomotion's Avatar
slomotion
slomotion is offline
Old 01-04-2013, 01:47 PM
UNWANTEDHOBO's Avatar
UNWANTEDHOBO
UNWANTEDHOBO is offline
Stage II
thinking about going with the 16 up front, what kind of rim did you use? and tripple tree?
Quick Reply: Need Help Lacing 16 inch front wheel - Street Bob
