where is the fuel pump relay?
Old 08-12-2012, 08:36 PM
ramu3527's Avatar
ramu3527
ramu3527 is offline
Default where is the fuel pump relay?
Can someone tell me where the fuel pump relay is on my bike (2009 FXDC)? The fuel pump isn't working from what I can tell. The bike got very wet as it sat in the rain all day yesterday. I ended up putting a new battery in it and it seemed to run fine. In fact I road it from Winston-Salem NC to Richmond VA. When I tried to start it at the hotel, no fuel pump prime and the bike cranks but won't start.
Is the relay that black block in the fuse block? There are two that look alike, one is white and one is black, the black one was pretty wet before I dried everything with a hair drier and it was making a weird noise when I tried starting it again. Now, nothing...
What I'm hoping is that's my fuel pump relay and it's just a matter of replacing it.
BTW, I'm over 800 miles from home with very limited tools...
HELP!!!
Ray
Old 08-12-2012, 08:56 PM
ramu3527's Avatar
ramu3527
ramu3527 is offline
Ok, stupid me, I looked on the inside of the fuse block cover and, what do you know, a diagram of what is what in the fuse block!
What it says in that spot is 'system relay'. Is that the fuel pump relay, I hope?
Old 08-12-2012, 11:54 PM
ynots's Avatar
ynots
ynots is offline
Bump for you
Old 08-13-2012, 01:28 AM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
The system relay does control the fuel pump/injectors. It would be worth it just to pull the cables and check the prongs on the relay to make sure they are clean and dry with no corrosion. If there is any, try to brush it off and see if it works again. There have been a lot of problems with water intrusion on the relays that randomly pop up.
Old 08-13-2012, 01:31 AM
onemyndseye's Avatar
onemyndseye
onemyndseye is offline
here ya go brother.. from the manual:
This may also help:
Old 08-13-2012, 07:27 AM
ramu3527's Avatar
ramu3527
ramu3527 is offline
Thanks guys... I'll be looking into it...
Old 08-13-2012, 08:41 PM
ramu3527's Avatar
ramu3527
ramu3527 is offline
Got it, it was the system relay. Hope that it...
Thanks for all the help.
Ray
jlsmthrs97
11
06-12-2022 02:31 PM
Geoo
12-06-2019 12:57 PM
just plain john
08-28-2013 09:08 PM
HarleyMast
12-06-2010 01:42 PM
LedHed
05-27-2010 04:00 PM
Quick Reply: where is the fuel pump relay?
