Fuel Pump will not prime
Old Dec 6, 2010 | 07:47 AM
HarleyMast's Avatar
HarleyMast
Stage I
Default Fuel Pump will not prime
2008 Road King - Fuel Pump w/n prime I just replaced the battery (3 yrs old and I thought was going bad)
Figure has to be the fuel pump fuse or the fuel pump relay based upon other posts.
Never worked on Harley before.
Where is the fuse box and fuel pump relay physically located.
Not near bike right now.
Cheers Joe
Old Dec 6, 2010 | 11:48 AM
honestbob's Avatar
honestbob
do you hear the fuel pump running when the switch is on? The 07s and early 08s had a problem with the plastic bowl in the tank cracking. Just thinking.
Old Dec 6, 2010 | 12:39 PM
dawg's Avatar
dawg
The early 08's were the only ones with the fuel filter shell issue. If you've ever brought it into the dealer for service and yours was an affected VIN then they would have/should have caught it. The fuses are under the left side cover.
Old Dec 6, 2010 | 01:42 PM
oldairboater's Avatar
oldairboater
Could be a good idea to get a HD repair manual specific for your bike. As others have stated some HD's had pump problems those years. As stated above you should hear the pump ramp up. I can't describe the noise but I recognize it when I power up the bike.
jlsmthrs97
11
Jun 12, 2022 02:31 PM
DavidStiebel
Sep 7, 2012 11:51 AM
LedHed
May 27, 2010 04:00 PM
smclaren
Mar 29, 2010 09:55 AM
floridian46
May 20, 2007 08:44 PM
