Super Glide Windshield Buffeting/Turbulence
Old 09-25-2012, 09:08 AM
MiniWolf's Avatar
MiniWolf
MiniWolf is online now
Moderator
Received 4,688 Likes on 2,258 Posts
Default Super Glide Windshield Buffeting/Turbulence
Anyone who uses a windshield on their Super Glide Custom, can you offer any advice on alterations or adjustments you made to deal with turbulence and buffeting?
I have the 18 Inch HD detachable windshield.
Buffeting and turbulence begins right around 60MPH. It progressivley becomes more severe as speed increases. At legal highway speeds of 65(70) the turbulence is bad enough to be a major concern. There is massive head buffeting and side-to-side oscilations. I experimented by trying to position my torso closer to the screen to try to find the envelope. I have to almost press my upper body against the windshield to get out of the vacuum zone and into turbulence-free zone. The air pocket stretches pretty far back.
Searching online, I have read that helmets can have a major impact. I have two helmets--Full Face and 3/4 with face shield. I noticed no discernable difference between the two but in both cases noticed that the buffeting is marginally better with the face shield down than up.
With the stock seat, the turbulence and buffeting is less severe, compared to the Mustang vintage wide touring seat. Obviously, the Mustang sits me a bit higher so this is understandable. In either case, however, it becomes a wild ride once I get up to 60.
Old 09-25-2012, 09:15 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i took a road glide lower damper... shaved the sides and drilled center... mounted that under my tree's... works fantastic!... then of course i powder coated it gloss black
Bagger_Vance's Avatar
Bagger_Vance
Bagger_Vance is offline
Same thing with mine.
Old 09-25-2012, 09:29 AM
Loner88's Avatar
Loner88
Loner88 is offline
Found that a tool roll bag hanging off lower tripe tree helps- maybe as much or not as much as Joe's touring baffle- keeps the road grit off the steering damper rods too. This guy had one of the better answers, if ya could deal with the look, he's no more, but maybe you could whomp up something like it at home:
https://www.hdforums.com/forum/dyna-...t-results.html
Old 09-25-2012, 09:33 AM
Bagger_Vance
Tell me more about what you did Joe. Any other pics?
Old 09-25-2012, 09:40 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
all i did was get a stock damper, shave the L off the back where it mounts stock, and i think i cut it like 1 inch per side so that it would tuck in the trees and not rub my boots... form there found center... marked it... drilled a hole so i could use my headlight bolt to mount it into place... i have my turn signals under there so i was able to use my damper mount and some fender washers i powder coated in gloss black to space the air damper away... works great... i can snap some more pics of it when i get back to the house i rode my sport touring today
Old 09-25-2012, 09:51 AM
Reindeer's Avatar
Reindeer
Reindeer is offline
I've got so much buffeting with my detachable windshield I hardly ever use it. It seems to block some of the wind from hitting me in the chest, but my beard flies straight forward and flaps up into my mouth, which is kind of annoying.
Old 09-25-2012, 10:20 AM
scooter1128's Avatar
scooter1128
scooter1128 is offline
when sitting in the riding position, are you looking thru the windshield? if shield is lower than line of sight, how much lower is it?
Old 09-25-2012, 10:52 AM
Griff012FLHX's Avatar
Griff012FLHX
Griff012FLHX is offline
Heres my solution....
Rifle Roadster Fairing....
No Buffeting with either FF helmet or a Beanie....
Old 09-25-2012, 10:58 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i will also add that i NEVER had buffering at all with my old QR shield even with the lowers attached to it
it was not till i put on the full fairing that i have buffering and installed the lower air damper
Quick Reply: Super Glide Windshield Buffeting/Turbulence
