I started my 2005 dyna superglide today to go for a ride and it started just fine but it reved up the rpms quite high and stays there? I havnt started it for 2 weeks and live in a very cold climate. Today it is not to cold here around 30 degrees and it has been in the garage. The only thing I can think is I changed out the factory air cleaner for a aftermarket set up but it ran fine before I parked it 2 weeks ago for the snow storms. It is EFI by the way. I also shut it off and restarted it just as easy 2 more times as the first time and it just stays in a high rev. If I roll back on the throttle some it will just rev up a bit more and on release it goes right back to the high rev...if I crack the throttle fast it will just back fire and then go back to the high rev..... any help would b appreciated as I would like to ride today!
I just let it run about a minute or less when each time I started it. I didnt know if it was bad or not to let it start up that high of an idle so didnt want it to run to long. I just put the factory ac set up on it and it is still doing the same thing?
