Sissy bar from scratch
Hey guys, looking to make a sissy bar from scratch. I'm a welder, so the fab is no problem, but what im tryin' to figure out is a way to quick-detach it like i see on alotta other ones. I don't have one to go off of, so I guess im wondering what hardware I could use on my struts (I don't use the covers) to make it go on and off easy. Thanks in advance.
you can always make a plate to fit the fender struts bolts. Get some bolts that is 1/4inch longer or so. Cut a slot on the front bolt for the mount making it forward, toward the engine. On the back bolt make the slot downward. This way it can slide in toward the engine and down on the rear just by losing the bolts. You may want to add washers between or spacers to keep from scratching the fender strut. I have made a lot of these, pretty simple and easy to make. You can either use square thick wall tubing or solid round rods. Weld or bolt together. If you are wanting a luggage rack you can take care of that at the same time.
I make most of my stuff like this. Cost less and I can do it like I want.
powder coat or chrome.
I use 1/4 sheet cold roll
If you buy the HD detachable kit as mentioned in the post above, make your side plates out of 1/8" steel. Then you will need to fabricate some kind of lock on them which is easy to make. A simply piece of 3/8" steel cut to fit the mount is what you need. I have several of these with a bolt and a small spot welded on the bracket to prevent rolling.
