Wobble
Wobble
So I was heading home from work today. It was nice out , so I took the long way home. Opened up to around 75 and it started to wobble. More like rock, from right to left, pretty freaking scary. I've had this bike for a couple of months and put a few hundred miles on it and this is the first time this has happened. It was windy today, but it's not the first windy day I rode. I have a 96 Dyna Convertible, it only has 5800 miles on it. The windshield that's on it is a replacement, not original. SO could that have been the cause? It did clear up further down the road. It's a road that I've been on many times before on my last bike with no issues, so I don;t know what that could have had to do with it. Any ideas on what I should check. I looked around and saw nothing that looked out of place. Any help would be appreciated. Thanks.
If the road had high berms of bunds either side it could be the cause....there is a section of HWY 1 that I ride regulalry and the bunds knock the wind about making it a real pain to ride through even when not particularly windy.
Also, try taking any balance weights off the front wheel and see if this makes a difference.
There are a lot that can cause this.
Bad tires, cupped tires, low tire pressure, neck bearings need adjusted, road condition, etc...
I would consider to checking for normal wear items first and check it on a different highway that is in better shape.
Just ride and see if it does it again.
Ok, at the suggestion of a friend, I jacked my bike up and tried moving the rear end to check the swing arm. I notice some movement from side to side. It wasntn't much, but I didn't think it should move at all. So, does this mean I need to replace the bearing and or bushing's? Or is some movement normal? Thanks.
