Missing bolt/fastener next to transmission assembly?
Hello,
I recently installed a Supertrapp 2:1 Supermegs exhaust on my 2010 FXDB Street Bob. When I removed the stock rear exhaust bracket it contained 2 bolts that went into the transmission assembly and a fastener just to the left. When I went to put on the Supertrapp muffler support bracket it only contained 2 fasteners that went into the transmission assembly leaving a hole where the previous fastener went. I thought maybe I just needed to put the orignal stock fastener back in, but it was too long and stuck out. I tried looking online but all the pictures I see look to have a fastener plugging up that hole.
Anyone have any ideas? Can I just leave it open or is there a fastener or plug I should put in there? It seemed like that hole is only there for the stock muffler bracket, but I could be totally wrong...wouldn't be suprising as I'm pretty new to working on my HD
Attached are two pictures: stock bracket with the 3 bolts and the Supertrapp bracket that only covers 2 holes leaving a hole open.
UPDATE: This is what I got back from Supertrapp:
I'm going to run to the hardware store and get a different bolt.
I have confirmed this with our Engineers, that is a blind hole that does not serve any other function other than for the stock exhaust bracket.
So you could leave it empty, get a smaller screw, or use a washer with your current screw. The washer should take up the difference without the stock bracket.
Use the two black holes. The silver hole is the blind hole.
